Roof To Wall Flashing. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2007, 11:50 PM   #16
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Doesn't that give you a pin hole in the corner?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-23-2007, 10:44 AM   #17
Rewards Points: 398
The kickout flashing's purpose is to kickout water. In your case it will be at the end of the run. I guess you could seal it. If you didn't have a kickout it would end where you made the cut. I don't see any problems, but a real roofer may come along shortly. I am just a DIY person.
Malcolm is offline   Reply With Quote
Old 07-23-2007, 11:06 AM   #18
To avoid the "pin-hole" leak potential, I take 2 pieces of step flashings, cut the opposite miter angle on the bottom piece, apply a slight bead of sealant, then sandwich the 2nd piece of step flashing on top of the 1st one with the exact opposite angle of the miter cut.
Or, you could purchase a "kick-out" flashing from a company who makes them.
Here is one link.
http://www.dryflekt.com/
Ed
P.S. Galvanized nails are constantly used to install the aluminum step flashings, aka baby tins. The step flashings are typically nailed into the side wall portion of the flashing.
Ed the Roofer is offline   Reply With Quote
Counter flashing where roof meets vertical brick wall sandyman720 Roofing/Siding 5 02-20-2011 11:13 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 05:16 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Roof to Sidewall Flashing handyman923 Roofing/Siding 1 09-13-2006 05:02 PM
