-   -   roof to wall flashing. (http://www.diychatroom.com/f9/roof-wall-flashing-9966/)
Clutchcargo 07-17-2007 08:42 PM
63 Attachment(s)
How do I flash the roof 2 wall transition. I'm rebuilding my portico. The way it was originally built, the first rafter was nailed on the shingles.
Is there a product that makes the roof 2 wall easy or do I need to bend a piece of aluminum and make it work somehow?
http://www.gutcruncher.com/images/House/Portico1.jpg
gregzoll 07-17-2007 09:20 PM
You can use the rubber flashing as a shield, but use Step flashing over the top to shed the water down and away. The only thing about the rubber flashing, is that you will have to remove some of the wooden siding to install.
Clutchcargo 07-18-2007 06:03 AM
63 Attachment(s)
I'm residing at the same time so all the siding is coming off.
I was going to put ice and water shield over the entire roof and run a few inches up onto the wall and then weave step flashing in with the roof shingles. Where I'm having trouble understanding is the first piece of step flashing. How do I keep the roof from draining behind the siding?
TIA
gregzoll 07-18-2007 07:05 AM
The Rubber flashing will shield it, along with the step. When you do the whole setup, it will go from bottom to top, with the next layer being over the edge of the next.
AtlanticWBConst. 07-18-2007 07:12 AM
TIA
These 2 links may help you:
http://www.housingzone.com/topics/pb.../pb03ga007.asp
(In this video link, it is not required that you dress like the guy in the video wearing the jean cut offs and the bandana :wink: ): http://www.hgtvpro.com/hpro/pac_ctnt...&videoid=63326
Clutchcargo 07-18-2007 08:24 AM
63 Attachment(s)
Ok, the kickout flashing makes sense. Is that a product that's available or is that something that is made on the site from step flashing?
gregzoll 07-18-2007 12:35 PM
Kick-out is made on site. If you do not have a Brake for sheetmetal, you will have to improvise.
Ed the Roofer 07-18-2007 03:14 PM
It also can be made from a standard baby tin step flashing.
Take your tin snips and cut on a 45 * angle and bend the bottom portion upwards, so the sheet metal on the top portion overlaps the sheet metal on the bottom portion. Ice and Water shield behind the step flashings is also a good idea, especially since you will have the siding removed.
Ed
Malcolm 07-21-2007 10:01 PM
Can you make a kickout flashing using galvanized L flashing? I wasn't sure if it would rust since it was cut.
gregzoll 07-21-2007 10:18 PM
You can use Aluminum or Copper, then you do not have to worry about rusting.
Ed the Roofer 07-22-2007 02:07 PM
If you use a copper step flashing in direct contact with aluminum step flashings, then the aluminum one will disintegrate from a "Galvanic" reaction.
Make sure you use compatible metals in direct contact with each other.
Ed
Malcolm 07-22-2007 03:36 PM
All I have access to is really thin aluminum step flashing. Can I cut a piece of galvanized metal for the kickout? I mean people use galvanized all the time and have to trim it to size.
Ed the Roofer 07-22-2007 04:40 PM
Galvanized sheet metal is closer to aluminum on the "Galvanic Chart" than aluminum and copper are.
It is still two dis-similar metals and not hight recommended, but they will not have as an intense of a reaction as the copper has to the weaker aluminum metal.
Ed
Clutchcargo 07-22-2007 06:53 PM
63 Attachment(s)
I sounds like you need to use aluminum nails as well; is that correct?
Are there any pictures online on how to bend a kickout into shape?
Malcolm 07-22-2007 09:26 PM
I cut the 45 degree cut and placed a 2X4 block at the cut. I then just bent the metal around the 2X4 (not all the way). It worked for me.
