Roof Vents Necessary In Moderate Climate? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-11-2012, 12:00 PM   #1
Roof vents necessary in moderate climate?
The roof of my house does not have any vents. I'm not noticing any problems so far. Iím wondering if they are really necessary as I live in San Francisco where it rarely gets very hot or very cold. Any advice is appreciated.
diyun is offline   Reply With Quote
Old 03-11-2012, 04:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 840
Ventilation is not a hot or cold issue but a moisture issue.
I guarantee you that you reach dew point regardless of the mildness of your climate.
Depends on the roofing system but most homes are based on ventilated designs.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (03-11-2012)
Old 03-11-2012, 09:49 PM   #3
Rewards Points: 626
you have to have ventilation in your roof unless you don't cook bath shower breath or live in your home. Moisture vapor is your home and it needs to vent some how. Wither it is from soffets vents to ridge vent or gable vents your roof has to breath
Nailbags is offline   Reply With Quote
Old 03-12-2012, 12:57 AM   #4
Registered User
Rewards Points: 4,894
Welcome to the forums!
1. How long have you lived in this house and noticed "no problems"?
2. Do you have a plastic vapor barrier under the floor insulation?
3. Are there HVAC units or ducting in the attic?
4. Has the attic ever been air-sealed? All plumbing/wiring holes to the rooms below been plugged with canned foam/caulking. Around light fixtures, plumbing chases, etc.
5. Has the basement/crawl- if one- been air sealed?
Gary
Old 03-12-2012, 02:57 PM   #5
Stroudsburg Roofer
PAHome's Avatar
Ventilation is definitely a must. First of all it validates your warranty. It will make your roof last longer.
You always want to keep the inside of your roof close to the temperature on the outside that way you don't have condensation build up inside your roof.
PAHome is offline   Reply With Quote
Old 03-12-2012, 05:52 PM   #6
Rewards Points: 840
All recommendations for ventilation should probably be tabled until the poster actually identifies the type of roof that they have.
seeyou (03-13-2012)
Old 03-17-2012, 06:25 PM   #7
Gary,
Apologies for the late response. Here are answers to your questions.
A: 3 years.
A: There is floor insulation in the attic but no plastic vapor barrier underneath it.
A: Yes, one heating duct from a forced air heater goes thru the attic.
A: I do not believe it has been air-sealed.
Thank you very much.
Kevin
Old 03-17-2012, 06:27 PM   #8
To answer "Windows on Wash's" question. I have an asphalt shingle roof. Let me know if you need any more details.
Thanks so much!!
Old 03-18-2012, 12:57 AM   #9
Registered User
Thanks. Air sealing is plugging all attic holes as you have done already. Insulating to minimum R-value for your area is required. Wrapping the heat/ac duct with insulation and a vapor barrier is needed. I would air seal the holes/chases in the basement/crawl to help stop the "stack effect": http://www.wag-aic.org/1999/WAG_99_baker.pdf
With the moisture in the air from the Bay nearby, you may not need/want venting, pp. 4,5: http://www.wag-aic.org/1999/WAG_99_baker.pdf
Air sealing importance: http://www.jlconline.com/cgi-local/v...170a32100a05c7
Shingle life (though may lose the warranty); http://www.professionalroofing.net/a...2/feature2.asp
Compare your climate to those quoted. We have thousands of 1900's built houses in my area non-vented, still standing.
Gary
Insulate Attic. No soffit vents. Roof vents yes. jefsboys Remodeling 14 06-29-2012 12:40 PM
Roof Vents for Very Hot Second Floor somewhatsketchy Roofing/Siding 1 08-11-2010 11:54 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 11:31 AM
