Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-27-2011, 09:11 PM   #1
Roof vents
Hello all. First time poster....please be gentle.
Looking for opinions on roof ventilation. I have an attic space over the back half of my house that is accessible via a hatch on the second floor of the front half. It gets REALLY hot during the summers and I'm concerned about some of the items I keep in there. It's too much of a bonus not to have this space so I'd like to ventilate it better, in particular for the summer.
The space is 25x18. There are continuous soffit vents under the eaves and only a 12inx12in gable vent at the far end away from the house. I plan on sealing around the hatch so air doesn't bleed into the house. I'm assuming putting some more ventilation near the ridge may help, so I'm looking for input on......
Will regular passive slant vents help somewhat?
Would a ridge vent be better?
Is a ridge vent something I could do myself without any major catastrophies? ie.-causing leaks, etc.
Any input would be appreciated.
Thanks.
Dr.Fugazi is offline   Reply With Quote
Old 03-28-2011, 07:42 AM   #2
Shut in w/o Home
seeyou's Avatar
Roof vents
Either slant vents or ridge vent should help. Cosmetics would dictate which based on equal output.
To install ridge vent, you'd have to remove the ridge caps and cut back any of the tops of the shingles within several inches of the ridge. You'd then have to cut back the sheathing on either side, install the vent and re-install the ridge caps.
To install the slant backs, you'd need to remove several shingles for each unit. Cut your hole, install the vent and cut and re-install the shingles.
seeyou is offline   Reply With Quote
Old 03-28-2011, 01:50 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Roof vents
A continous soffit and RidgeVent IMO give you the maximum ventilation.Obviously slant back/turtle vents work too.I feel when applied according to manufacture specs RidgeVent with functionable soffit will out perform the vent and soffit combination.
Roofmaster417 is offline   Reply With Quote
Old 03-28-2011, 04:09 PM   #4
Roof vents
Thanks everyone for your input.
I think I could handle the slant vents with no problem myself. Question is....is it a bad idea to try to do a ridge vent myself? Is there a big potential to cause leaks?
Old 03-28-2011, 08:56 PM   #5
Roof vents
Also 2 quick thoughts........
Any thoughts on Cobra, Cobra 3, AirVent, etc.?
And if I do go with slant vents, leyward or windward side? Does it make a difference. The ones installed are on what is generally the leyward side for my location. Should I assume to roofers prior put them on that side for a reason and do the same?
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Roof Vents for Very Hot Second Floor somewhatsketchy Roofing 1 08-11-2010 11:54 AM
roof over need vents? jgreaves Roofing 3 09-25-2009 09:23 PM
Rubber Roof and Roof Deck vianak Roofing 2 10-09-2008 06:37 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing 5 10-26-2006 11:31 AM
