Roof Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-03-2012, 09:06 AM   #1
Rewards Points: 2,144
Roof vents
My house has the most roof vents I've ever seen. The less cuts in a roof the happier I am and I was always told the more holes the more chance of leaks.
This house is 29 yrs old. The laundry is vented thru the roof, but nothing I can do about that as it's in the center of the house. I'd prefer it thru the side wall.
I just realized the stove exhaust fan is also vented thru the roof. (one more hole).
When I reroof I think I'll tell the roofer to seal the stove exhaust and just use one of those non vented exhausts.
Is this a good idea?
Startingover is offline   Reply With Quote
Old 05-03-2012, 09:24 AM   #2
Rewards Points: 13,444
Poor idea, a properly installed vent does not leak.
A range hood with no vent does nothing to get rid of the moisture when cooking.
Higher moisture in a home can fog up windows, add moisture to the walls which can lead to mold, and will catch more dust in the air.
If you have any vents other then a ridge vent you could get rid of those and add a ridge vent.
Old 05-03-2012, 09:36 AM   #3
there are also 2 ridge vents.
I'll try to shrink some photos I have and post.
Roof vents vs ridge vents sparksie Roofing/Siding 3 05-28-2011 10:31 AM
Ridge or Static Vents on Multi-level Hip Roof texasprd Roofing/Siding 16 05-27-2011 01:38 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Roof Vents for Very Hot Second Floor somewhatsketchy Roofing/Siding 1 08-11-2010 10:54 AM
roof over need vents? jgreaves Roofing/Siding 3 09-25-2009 08:23 PM
