Roof Ventillation Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-05-2013, 12:18 PM   #1
atm
Has anyone used the Maximum Ventilation model #301?
It is suppose to replace the regular roof venting (i.e. the square vents that come with builder roof). I currently have a 5 roof vents and thinking of closing the 5 and replaced with 1 Maximum Ventilation #301.
I'm looking to see if there are any downside or disadvantage to using the Maximum Ventilation to replace 5 regular roof vents.
Thank you.
atm is offline   Reply With Quote
Old 05-05-2013, 04:00 PM   #2
Roofmaster
Rewards Points: 2,210
Well you dont say where your home is, what type of roof you have, or what the slope of your roof is, so I guess we can only give you a generic answer.
Putting in an exhaust, without an intake is pretty much worthless. I just looked at the vent you are looking at, and there is no venturi effect, so I would suspect that their claims are questionable, as are most ventilation claims
The best way to add ventilation is to have continuous eaves ventilation and a good continuous ridge vent like Air Vent II. With this arrangement, you have convection working for you with an intake, and an exhaust. Obviously, the more slope you have, the better convection works. The lighter colored your roof is, the cooler your attic will be.
Old 05-06-2013, 01:30 PM   #3
atm
Thanks for your response.
Location is Toronto, Canada. I don't know what the slope is but the attic area is around 1000 sq ft. the roof currently has 5 of the square ventillators and there are soffit on the outside perimeter to provide air flow. I am going to replace the shingles and trying to decide what to do with the vents.
A roofer suggested that I should install the Maximum ventillator #301 to replace 3 regular square vents. I am not sure if I should stick to the original 5 square vents or install the #301 ventillator to replace 3 vents and keep the other two.
Any advice?
Old 05-06-2013, 03:28 PM   #4
Rewards Points: 656
If you have enough ridge, get ridge vents.
If your house has lots of hips and is very cut up, it might be best to stick with standards vents, I like airvent airhawks, in steel to keep the wildlife out.
Those maximum ventilators are expensive, and I cant see how they ventilate as well as they claim.
PatChap is offline   Reply With Quote
Old 05-06-2013, 06:28 PM   #5
Roofmaster
Any advice?
Did you read and comprehend my first response? Its right there in paragraph 3, really, it is.
Old 05-06-2013, 07:39 PM   #6
Doing This Way Too Long
Rewards Points: 532
A larger red font might have gotten your displeasure in the OP across a little more forcefully.
Lighten up
OldNBroken is offline   Reply With Quote
Poured Roof Question avodahfarm Concrete, Stone & Masonry 4 10-30-2012 12:46 PM
Cold Deck flat roof and insulation question... paredown Roofing/Siding 16 05-15-2012 05:11 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
Another roof ventilation question Jim F Roofing/Siding 9 05-13-2010 07:51 PM
roof leak question joshm Roofing/Siding 23 04-04-2008 10:44 PM
