Roof Ventilation Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-03-2013, 04:45 PM   #1
Roof Ventilation problem
I have a 7 year old home, the main roof is fine however the first floor addition roof needs replacement. I think it's due to improper ventilation. This inside ceiling is vaulted. I was thinking of installing a ridge vent on the peak in order to improve ventilation. Would a ridge vent work properly in this location and help my problem? or should I just add more louver roof vents? See picture.
rumrunner069 is offline   Reply With Quote
Old 06-03-2013, 07:57 PM   #2
Rewards Points: 646
I don't know if you have enough room with the low windows, but a clerestory wall vent would work well there. I've used lomancos omni-wall quite a few times in the same situation.
As long as the attic spaces are connected a ridge vent may be simpler however.
e- just noticed the vaulted ceiling, is it only on the gable section or the entire front?
There's a good chance that the 7 year life has as much or more to do with the shingles we had here 7 years ago than the ventilation, as well.
PatChap is offline   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
rumrunner069 (06-03-2013)
Old 06-03-2013, 08:20 PM   #3
Rewards Points: 13,690
Where would it get it's make up air from?
To get a ridge vent to work it has to be able to draw in cooler air from below.
Old 06-03-2013, 08:36 PM   #4
Thanks for the update re: my location this makes sense.
Re: air flow it will come up fine on the left hand side, however the right hand side of the peak is where I will have a problem. I was not convinced the ridge vent would work for my situation. I think the wall vent may work for the right hand side of the roof, but still have a problem with the right peak.
Old 06-04-2013, 04:09 PM   #5
Rewards Points: 646
You should find out if those are BP shingles, I would say there is a good chance they are. BP recently lost a class action lawsuit for the shingles they made in that era, would probably be worth it for the minor hassle of filing. Any BP dealer will have the paperwork.
Your roofs either BP or IKO, if you get me a better picture of the shingles I can probably/maybe tell you which.
Old 06-05-2013, 06:43 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
I would run some SmartVent on the roof deck near the wall.
You will have to pull some sheathing to see how the venting connects from the underside and to see if the soffit air is even able to get up there.
Nearly flat roof, with ventilation pipe, ice dams / leak - suggestions needed! highvoltz Roofing/Siding 6 11-02-2011 09:49 PM
Low Slope Roof Ventilation LDSGJA Roofing/Siding 8 07-06-2010 05:02 PM
Ridge roof ventilation rbdaniel33 Off Topic 1 06-02-2010 08:24 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
need some advice on best roof ventilation for this house longshanks Roofing/Siding 9 07-26-2009 06:49 AM
