Roof Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-10-2015, 03:58 PM   #1
kbt
Rewards Points: 8
Roof ventilation
I have an old house built in the 60s, with very poor roof ventilation.
I'm trying to improve it. Outtake vents no problem, but the intake soffit vents is what I'm trying to figure out.
From my research, it appears most houses have the part under the eave as part of the attic, and vents attached under there. For my house, it's not part of the attic, so I only have the vertical wall to make holes into.
Crude drawing here:
http://imgur.com/lqTacxz
I'm thinking about getting a 3" hole saw that can go through stucco, and adding these every foot or so:
http://www.homedepot.com/p/Master-Flow-3-in-Resin-Circular-Mini-Wall-Louver-Soffit-Vent-in-White-4-Pack-RLSC3/100038053
Will I get airflow through these vents if they are on a vertical wall instead of horizontal under an eave?
Is there a better way to accomplish this?
Thanks!
kbt is offline   Reply With Quote
Old 03-10-2015, 05:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,048
Roof ventilation
Any chance you can get a picture of the house? That's going to help out a lot more here with all due respect to your drawing.
There are plenty of retrofit eave ventilation systems that can work. Before you start cutting holes in the stucco, post up a picture it will give you some more directed suggestions.
Old 03-10-2015, 05:50 PM   #3
kbt
Rewards Points: 8
Roof ventilation
I'll take a picture tonight when I get home and post it up. No matter what kind of vent, I'm going to have to go through the stucco unless I only do vents that are through the roof, but I'm not sure how well those would work as intake vents.
Old 03-10-2015, 07:35 PM   #4
Roof ventilation
Roof side intake vents work quite well.
Old 03-12-2015, 07:00 AM   #5
metal guy
hardtroofing's Avatar
Rewards Points: 106
Roof ventilation
What kind of roof vents do you have or gable vents soffit vents will not help there is nowhere for the air to flow I would try to not cut stucco if I could help it send a pic or 2
hardtroofing is offline   Reply With Quote
Roof Ventilation - Gable Vents? DRILLINDK Roofing/Siding 3 05-20-2013 02:36 PM
roof ventilation quandary skeetman Roofing/Siding 3 09-18-2012 05:35 PM
Double wide roof construction / ventilation issue cgrfish Building & Construction 5 05-30-2012 10:21 PM
flat roof ventilation twinkle Roofing/Siding 3 11-13-2009 02:58 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
