Roof Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-30-2012, 07:15 PM   #1
roof ventilation
I am installing an asphalt roof on a home that was built in the 5o's with no soffits. Home has only gable vents. I would like to add box vents while replacing roof. Does anyone know if they are compatible?
lobo is offline   Reply With Quote
Old 10-01-2012, 09:07 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,862
Box vents and gable end vents can work if they are not spaced to close to the end walls.
Do you have an overhang?
AirVent has great informational resources on venting.
Old 10-01-2012, 09:55 AM   #3
Just another idea while you're playing with the venting... You could install a gable vent fan on one of the gables. I did that in a previous house and it helped to expel humid air and hot air. You can get a fan that has a thermostat and a humidostat on it. Once you wire it up it will kick on when it gets hot in the summer or humid in the winter.
NHtransplant is offline   Reply With Quote
The Following User Says Thank You to NHtransplant For This Useful Post:
Roofmaster417 (10-02-2012)
Old 10-01-2012, 10:26 AM   #4
Make sure the gable fan is humidstat and thermostat controlled.
Old 10-01-2012, 11:49 PM   #5
Registered User
Rewards Points: 5,216
Air-seal the attic first or you will exhaust your money spent conditioning the rooms below and replacing spent air with crawlspace/basement air (humid); http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Dangers of powered exhaust (with minimal intakes); http://www.advancedenergy.org/buildi...%20Studies.pdf
http://www.nachi.org/attic-ventilati...s-part1-25.htm
http://www.homeenergy.org/show/artic...page/4/id/1534
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
roof ventilation quandary skeetman Roofing/Siding 3 09-18-2012 06:35 PM
Double wide roof construction / ventilation issue cgrfish Building & Construction 5 05-30-2012 11:21 PM
flat roof ventilation twinkle Roofing/Siding 3 11-13-2009 03:58 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
