This Roof Vent Go On Top Of Which Layer ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-14-2011, 06:28 PM   #1
Rewards Points: 1,062
Question
this roof vent go on top of which layer ?
hi, i was wondering if the pictured roof vent should go on top of
A) asphalt felt
B) shingle at the very end
also, was wondering if the sloped part should be facing down hill (common sense says yes but checking).
thanks
this roof vent go on top of which layer ?-p1020615.jpg   this roof vent go on top of which layer ?-p1020616.jpg
Old 04-14-2011, 06:55 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
In your 1st photo, the left side (slanted) is the top. The right side (open) is the bottom.
The bottom goes over a shingle and then the next courses go over the vent.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
amakarevic (04-14-2011)
Old 04-14-2011, 07:04 PM   #3
so the opposite from what i thought. thanks.
Old 04-15-2011, 06:24 AM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Go under the vent until a shingle passes 1/2 or more of the hole in the roof, ideally. I like the first shingle on top to have it's upper edge ABOVE the top corner of the hood. Not always possible.
In this case, the owner made it above the corner, then caulked it diverting the water underneath. Not good. NO CAULK! Leave 1/2"-3/4" channel for water flow.
If the first shingle on top does not make it to the top corner, Taper it's upper, hidden section towards the upper lip so the lip and the taper come to the same spot. Cutting the shingle square will leave an edge to catch water and guide the water under the shingles. Not good.
tinner666 is offline   Reply With Quote
roof vent and vent stack gasket installation amakarevic Building & Construction 3 02-18-2011 01:09 AM
How hard is it to add a roof vent with no experience? Red Squirrel Roofing/Siding 3 05-18-2010 10:35 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Vent dryer through flat membrane roof Vince Rosati General DIY Discussions 6 11-02-2008 03:11 PM
