Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-10-2008, 04:29 PM   #1
Roof Vent Drip Edge
Hello all,
I am in the final stages of planning my shop build. After working with the city on ;ot set-backs and all, I need to have a fire rated wall on one side of the shop. It also can't have an overhang (eve) or any penetrations on this elevation. I plan on using a continous roof ridge vent and a continous vented drip edge on the opposite side of the building. How should I vent the fire rated wall side of the building? Vents on the roof at the bottom of the slope?
Thanks, Keith
porschedude996T is offline   Reply With Quote
Old 01-10-2008, 04:40 PM   #2
Roof Vent Drip Edge
the underside of your rafters (wall to 4' up) may also need to be covered to complete your fire rating. Check with your code people. You may need to vent from gables or power vent.
Big Bob is offline   Reply With Quote
Old 01-10-2008, 08:19 PM   #3
Super Moderator
Roof Vent Drip Edge
Try using this. They have a mid-roof and an off peak installation method both for intake and exhaust ventiolation.
It is called. Smart Vent by DCI Products, Inc.
http://www.dciproducts.com/html/midroof.htm
That page is for the mid-roof or slightly higher than the eave edge application method.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-03-2008, 07:04 PM   #4
Roof Vent Drip Edge
That page is for the mid-roof or slightly higher than the eave edge application methos.
Ed
Thanks Ed, I finally got my local Roofing Supplier to find it. Any idea what this stuff cost a foot. I'm planning to use the Smart Vent and the SmartRidge II.
Thanks,
Old 02-03-2008, 11:32 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
Roof Vent Drip Edge
it`s about 11$ for 3 ft. pieces
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 02-04-2008, 01:59 PM   #6
Super Moderator
Roof Vent Drip Edge
The previous price is close to what I pay, which is about $ 3.00 per foot.
I have read of some people paying much less than my supplier charges though, which may be due to geographical location and shipping costs.
I would still advise a ridge vent that contains and external baffle to promote additional exhaust venting though, such as the Shingle Vent II or Cobra Snow Country.
Ed
Old 02-04-2008, 02:03 PM   #7
Roof Vent Drip Edge
Ed
Ok, Thanks,
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing 8 05-03-2008 12:00 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Drip edge on a shed roof. Scott Roofing 2 10-04-2006 08:22 AM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 09:32 PM
