Roof Valleys - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-31-2009, 09:14 AM   #1
Roof Valleys
Is their anyone who could upload a closed weave format on how to correctly lay them to the top.I'm sure i'm doing it right,but man if i'm not.
Dyn'R is offline   Reply With Quote
Old 09-02-2009, 11:22 AM   #2
Well here's the first of many to come
"Bump"
..suppose you thought you could get rid of me that easily,my shingle-less roof ain't going anywhere anytime soon.
Old 09-02-2009, 02:00 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Since no-one else has responded, here is a link that shows a couple different methods to shingle a valley. Personally, I like the fully woven valley better than any of them.
http://www.roofer911.com/roofing-art...ng-valleys.htm
Old 09-02-2009, 02:11 PM   #4
Registered User
Rewards Points: 5,244
here's one more: http://books.google.com/books?id=VFT...age&q=&f=false
And 99 more: http://books.google.com/books?ei=h7S...ofing&as_brr=3
Be safe, G
Old 09-04-2009, 07:30 PM   #5
Thank you guys and or gals
Old 09-04-2009, 10:26 PM   #6
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
A full weave will only work right on roofs with the same pitch.
If two roofs with different pitches come together,a half weave would be better.
oldfrt is offline   Reply With Quote
Old 09-05-2009, 10:41 AM   #7
Roofing Contractor
Leftyho's Avatar
Hi,
A weaved valley is asking for trouble. Bridging is a big problem.
Only use 3-tabs if you are going to do a weave.
Leftyho is offline   Reply With Quote
Old 09-05-2009, 11:14 AM   #8
oldfrt's Avatar
Rewards Points: 186
Originally Posted by Leftyho View Post
Hi,
Could you explain what you mean by Bridging?
I've wove valleys without any integrity problems,so I was curious to what your saying.
Old 09-05-2009, 11:32 AM   #9
Roofing Contractor
Leftyho's Avatar
Hi,
You just did not see the problem.
It is impossible to get the shingle to completely conform to the change in plane. It will not lay completely flat. So you will have bridging.
A bridge spans an opening.
The lamanite will have gaps no matter what you do. It is just the nature of the shingle. 3-tabs are the only shingle you can weave safely. And that is if you pay attention to what you are doing.
Old 09-05-2009, 12:01 PM   #10
oldfrt's Avatar
Rewards Points: 186
I know what talking about now.
I've only seen this happen if you try and force the shingle in a direction it doesn't want to go.
Once the course side of the shingle is nailed,we let the valley side drop into place gently and nail it.
If your following the same plane consistantly across the valley,there doesn't seem to be any reason for bridging,unless one nail is put in the shingle across the valley and then it is pushed down for a second nail,litterally,twisting the shingle.
I can see this happening only if the valley had a dog leg in it,as you would be starting to change planes,but not on a straight valley.
I just grabbed a Timberline and bent it to simulate a valley application,there was no bridging,unless the shingle was twisted out of plane.
We've done these weaves for 25 years without any problems or call backs.
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
