Roof Underlayment Plywood - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-02-2013, 09:29 AM   #1
roof underlayment plywood
I'm replacing a roof and after removing the shingles I discovered the decking is the old formwork for the basement (constructed in 1955), there are many areas of delamination and it is weak and flexible in a Lot of areas. What is the best fix? I'm considering putting a layer of 1/4" plywood over the entire surface or just using a heavier underlayment like an Ice and Snow Shield over the entire thing. Suggestions Please.
Thanks,
Tom
Magrudet is offline   Reply With Quote
Old 07-02-2013, 10:21 AM   #2
Rewards Points: 12,868
If it's that bad it gets removed and replaced not just covered over.
1/4" would do nothing.
A picture would be real nice.
Old 07-02-2013, 11:57 AM   #3
Roofmaster
Rewards Points: 2,172
I completely agree with JoeC. Remove existing to rafters, correct any problems in rafters and clean them. Replace deck with 19/32 Fir plywood, nailed 6 inches on center on the ends and 12 inches on Center intermediate with 8d resin coated nails. Space sheathing 1/8th inch all around. Installing 1/4 inch is worthless and will actually cause more problems by pumping the nails out through the shingles.
Old 07-02-2013, 01:27 PM   #4
Thanks and DANG!
Old 07-02-2013, 01:55 PM   #5
Roofmaster
Originally Posted by Magrudet View Post
Thanks and DANG!
Better Dang now than Damn later.
The Following User Says Thank You to jagans For This Useful Post:
OldNBroken (07-04-2013)
How to attach a piece of 2x to the bottom of plywood roof deck? miamicuse Building & Construction 6 06-27-2012 09:52 PM
Bakor 1 ply vs Torch down samson56 Roofing/Siding 6 06-03-2011 02:56 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Sheet Vinyl....plywood underlayment or luan? AllGoNoShow Flooring 3 05-28-2008 06:57 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
