Roof Underlayment? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-28-2006, 05:00 PM   #1
Roof Underlayment?
I am always interested in finding out what other people believe in when it comes to sharing best practices.
I have never heard that Ice & Water shield is a bad thing for a roof above eaves, in valleys, around roof penetrations, etc or on 4/12 roofs or lower. However, the point of discussion I raise surrounds the requirement for felt.
To Felt or not to felt? That is the question.
I have an opinion on it of my own, but I would like to get some feedback, and hopefully from both sides of the coin.
http://www.kwroofing.ca/
Cheers
Steve
KWROOF is offline   Reply With Quote
Old 08-28-2006, 05:09 PM   #2
Home Improvement Guy
ron schenker's Avatar
I vote....to felt
ron schenker is offline   Reply With Quote
Old 08-29-2006, 12:37 AM   #3
renovations
I put felt on all sloped roofs, 30# at the eave and 15# in the field. Is that what you're asking?
Bonus is offline   Reply With Quote
Old 08-29-2006, 06:34 AM   #4
General Contractor
joasis's Avatar
There are newer products out there, like tri-flex and similar, but we still use tried and proven felt. I am south of the ice and water shield zone, so roofing techniques farther north are different in a few ways then I have done.
joasis is offline   Reply With Quote
Old 08-29-2006, 07:38 AM   #5
Rewards Points: 150
You have to use felt, not only is it code "Massachusetts anyway" but its just about all manufactures specs. read the fine print
do it right
RooferJim
RooferJim is offline   Reply With Quote
Old 08-29-2006, 04:40 PM   #6
were does the snow and ice region start? I live in north missouri and have always used ice barrier, am I required to
mattp is offline   Reply With Quote
Old 09-03-2006, 06:18 PM   #7
The Flying Toolbox
handypilot's Avatar
I would certainly felt! Like RooferJim said, if you don't, you could void the warrenty and/or bust code. Additionaly, some brands of arcitectual shingles require 30# over whole roof.
Code ussually requires at least 15# felt (or equivelant), and if the shingle manufacture requires 30# then that must be installed.
handypilot is offline   Reply With Quote
Old 12-08-2006, 08:18 AM   #8
Thank you very much for your feedback. It is what I believed to be true.
Manufacturers, such as GAF and ELK say that it is not required for warranty for their Arch. Shingles here in Canada.
We use Ice & Water rather than felt up here for application on the valleys and above the eaves.
My question is more geared towards above the 3ft line above the eaves, and on steeper pitch roofs such as 8 12 or greater.
Old 12-08-2006, 02:59 PM   #9
Rewards Points: 150
I wonder why GAF and ELK would require felt here but not up in Canada? strange.
RooferJim
Old 12-08-2006, 06:32 PM   #10
renovations
I haven't used GAF but have used Elk in the past, and as far as I remember the packages call for 30# and 15# in the field. Why wouldn't you put it down? It's cheap and fast, and if you do it carefully you can use it to make sure you're not 'fanning' the tiles as they go down.
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
