#1 |
Roof Tarp Nails
Hey Pro's,
We are putting a second story addition on my one story house. So far everything is going OK. My question is when the framers leave at the end of the day they stretch the tarp over the new trusses onto the lower roof. They seem to just nail through the reinforced edges of the tarp right into the shingles. It would seem after a week of doing this they must have nailed a hundred holes in my existing shingles and roof deck. Sometimes they stretch the tarp clear to the other side of the roof so I know there are nail holes pretty much everywhere on my existing roof. Are these nail holes something to be concerned with? The contractor says they will replace the shingles with the holes but I imagine there is no way to see all of these and get all of them. What do you guys think? |
#2 |
Roof Tarp Nails
You might need a new roof. I can't see them being able to find the nails. Plus there will be holes in the shingles underneath, so they will have to pull up a bunch, and then it all depends on how much effort they put in. I would make them replace everything.
#3 |
Roof Tarp Nails
There must be a better way to do this than nails through the shingles. Couldn't they use a tarp wide enough so they could fasten it to the sides of the house to dry it in?
#4 |
Moderator
Roof Tarp Nails
I spread a 60 x 40' tarp over the addition, temporarily nailed at the top wrapped in a 2x4. The bottom corners and every 6' have a rope tied through the grommets with a tennis ball attached to the 50' ropes(end of rope knot in slit in tennis ball). Toss the ball, ground man pulls the tarp, attaches to the fence, house, etc. Only the top holes (stay the same- daily) need replacing of shingles.
On a 1-story addition below a 2 story house eave (Tails), tie one end of tarp under house tails, attach pulleys (8' on center) like a bamboo shade to the eave underside (with lag eyes). Wrap a 2x4 along the bottom edge with the ropes looped around. Daily lift and tie-off the ropes after the giant shade is lifted to work. Get one big enough (or several) to cover addition while installing trusses/rafters in bad weather. Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#5 |
Roof Tarp Nails
If they are nailing in the same shingles everyday,it should be an easy fix.If they are nailing in different locations everyday they are idiots.There are many ways to secure a tarp without penetrating a perfectly good roof.Tell them your concerns.They should at the very least be marking the nail holes,so you know where the hell they are!!
| Display Modes | |
| Flat roof repair/replacement questions | zmt | Roofing/Siding | 4 | 02-23-2010 12:24 PM |
| Need Advice ASAP. New home, seller is paying to replace roof | elpa | Roofing/Siding | 4 | 02-18-2010 08:03 PM |
| Extend House Roof Over Back Deck | Justahome | Carpentry | 1 | 04-03-2009 08:25 PM |
| Flat roof - Rolled? - leaks Advice? | JJ2001 | Roofing/Siding | 4 | 11-19-2006 07:17 AM |
| Seller covered bad roof up, suggestions? | imetal | Roofing/Siding | 11 | 03-05-2006 09:03 PM |
