Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-28-2009, 09:56 PM   #1
Roof support questions
Hello. My attic is a pretty typical attic. There is a flat 4 foot wide space down the middle and off of both sides extends diagonal 2x4's that are on I would guess a 40 degree angle to the roof joists.
Basically, I want to know if it's bad to remove one of these supports so I can have an opening through the diagonal 2x4's in order to store boxes under the rows of 2x4's? I want to put down some plywood under the diagonal 2x4's to create some more storage space. I just need an access point to get through them.
Will removing one of these diagonal 2x4's compromise the integrity of the structure?
thanks for reading. I hope that made sense.
Mikey Palmice is offline   Reply With Quote
Old 04-28-2009, 10:14 PM   #2
Xtreme DIY'r
They are most likely supports
Removing one could cause a problem with the roof
Post a pic if you can
If all rafters/ceiling joists etc are 2x4 then it is a truss system & you can't touch anything
Old 04-28-2009, 10:18 PM   #3
I will take a pic tomorrow when I can get up there. I'm not sure if it's 2x4 on top or just the diagonal ones.
Old 04-28-2009, 10:44 PM   #4
how do I post a pic that is on my PC? Is that possible?
Old 04-28-2009, 11:49 PM   #5
Super Moderator
Read the topic at the top of this forum.
http://www.diychatroom.com/f9/how-at...to-post-20532/
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 04-29-2009, 11:20 AM   #6
Ok, I think that worked.
Old 04-30-2009, 04:01 PM   #7
So, based on this pictures is it safe to say that it would not be ok to remove one of these supports?
I was thinking of even cutting the top one and putting a cross piece 2x4 above the entrance to the storage area.
So, yah or nay?
Old 05-01-2009, 10:25 AM   #8
Your Roof will definetely sag if 1 is removed.
This roof is hand framed & there is an option.
If you take 1 out, don't go all the way to the rafter.
Put in a double 2x6 on the diagonal as you would when installing a header for a door or window.
This shoud be enough but you could install cripples on both sides as well
Dale Chomechko
DC Roofing Inc
DCL Contracting Inc
Dale Chomechko is offline   Reply With Quote
Flat roof related questions christy123 Roofing 8 12-10-2008 12:30 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
