-   -   Roof support questions (http://www.diychatroom.com/f9/roof-support-questions-43466/)
Mikey Palmice 04-28-2009 08:56 PM
Hello. My attic is a pretty typical attic. There is a flat 4 foot wide space down the middle and off of both sides extends diagonal 2x4's that are on I would guess a 40 degree angle to the roof joists.
Basically, I want to know if it's bad to remove one of these supports so I can have an opening through the diagonal 2x4's in order to store boxes under the rows of 2x4's? I want to put down some plywood under the diagonal 2x4's to create some more storage space. I just need an access point to get through them.
Will removing one of these diagonal 2x4's compromise the integrity of the structure?
thanks for reading. I hope that made sense.
Scuba_Dave 04-28-2009 09:14 PM
They are most likely supports
Removing one could cause a problem with the roof
Post a pic if you can
If all rafters/ceiling joists etc are 2x4 then it is a truss system & you can't touch anything
Mikey Palmice 04-28-2009 09:18 PM
I will take a pic tomorrow when I can get up there. I'm not sure if it's 2x4 on top or just the diagonal ones.
Mikey Palmice 04-28-2009 09:44 PM
how do I post a pic that is on my PC? Is that possible?
Ed the Roofer 04-28-2009 10:49 PM
Read the topic at the top of this forum.
http://www.diychatroom.com/f9/how-at...to-post-20532/
Ed
Mikey Palmice 04-29-2009 10:20 AM
2 Attachment(s)
Ok, I think that worked.
Mikey Palmice 04-30-2009 03:01 PM
So, based on this pictures is it safe to say that it would not be ok to remove one of these supports?
I was thinking of even cutting the top one and putting a cross piece 2x4 above the entrance to the storage area.
So, yah or nay?
Dale Chomechko 05-01-2009 09:25 AM
Your Roof will definetely sag if 1 is removed.
This roof is hand framed & there is an option.
If you take 1 out, don't go all the way to the rafter.
Put in a double 2x6 on the diagonal as you would when installing a header for a door or window.
This shoud be enough but you could install cripples on both sides as well
Dale Chomechko
DC Roofing Inc
DCL Contracting Inc
