Roof Staining/Algae Removal Products - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-02-2011, 02:32 PM   #1
does anyone have any product recommendations to kill off this algae on my roof? Will a home made solution with bleach do the trick??
teamcampreder is offline   Reply With Quote
Old 08-02-2011, 11:35 PM   #2
Rewards Points: 1,088
A bleach spray would work, but most roofers can install a zinc strip near the peak of the roof and as it rains, water will react with the zinc strip and kill the stain.
handy man88 is offline   Reply With Quote
The Following User Says Thank You to handy man88 For This Useful Post:
teamcampreder (08-03-2011)
Old 08-03-2011, 07:24 AM   #3
Residential Roofer
Slyfox's Avatar
The zinc strips doe's slow down/help but they will not stop the process.
Home made or store bought make sure what you use is safe for your animals and lawn, etc.
In my area the store bought products run about $25.00 give or take.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
Old 08-03-2011, 08:04 AM   #4
Is this a product I could pick up at a home depot or similar?
Old 08-04-2011, 06:45 AM   #5
Residential Roofer
Slyfox's Avatar
Yes, HD, Lowes, some lumber supply stores like Carter Lumber and probably some hardware stores like ACE.
Facebook <> Twitter
teamcampreder (08-04-2011)
Old 08-04-2011, 08:19 AM   #6
Great, thanks! Will report back with what I used and the final results.
Old 08-04-2011, 08:43 AM   #7
You may have to use a solution. There are a few other threads discussing this. In my experience the zinc strip does well to prevent algae.
Roofster is offline   Reply With Quote
Old 09-05-2011, 11:58 AM   #8
Taking stuff apart is fun
Is this type of thing something to be concerned about or just aesthetic? I have the same but MUCH worse than the images. Thanks!
butchbs1985 is offline   Reply With Quote
Old 09-05-2011, 06:34 PM   #9
Rewards Points: 150
There is a relatively new product called"spray it and forget it" you just spray it on and leave it and it works over time. I haven't used it yet, so you should research their website first and get customer reviews. They sell it at Ace Hardware.
guest is offline   Reply With Quote
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
