Is Roof Spread An Issue With A Reinforced Concrete Belt Course? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2007, 07:46 PM   #1
Is roof spread an issue with a reinforced concrete belt course?
I asked basically the same question over in the general construction section but if it's not a problem I'll ask again - sort of.
Is roof spread an issue with a reinforced concrete belt course toped by a 3" x 6" or 3" x 8" anchored plate?
The building depth is 26’ and we’re talking a 9/12 pitch using 2x6’s or 2x8’s.
If I do have to use a ridge beam, please suggest a size (in sawn lumber – we have no engineered lumber here in the Bahamas).
The length of the building is 30’. Can I use 1 support at the center along with the end support or should I use two. I’m thinking of using 2/ 4x4x1/4 lolly columns (dividing the load into three).
boyblue is offline   Reply With Quote
Old 05-07-2007, 08:13 PM   #2
Commercial Roofing
AaronB's Avatar
Doesnt sound like it...
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
How to drill 6-8" hole in reinforced concrete? Jemo Remodeling 2 02-26-2007 01:36 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
