Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 09-13-2006, 02:19 PM   #1
Roof to Sidewall Flashing
I have an existing asphalt shingle roof that meets a sidewall. Unfortunately, the underlayment does not lap up the wall and there is no step flashing. And of course, the siding and sheathing has now rotted. I am in the process of replacing the siding and sheathing on the sidewall, but am wondering the best way to flash this. I can easily add step flashing to the existing roof, but I can't think of an easy way to add underlayment without removing shingles. Any ideas?
Thanks!
handyman923 is offline   Reply With Quote
Old 09-13-2006, 05:02 PM   #2
Commercial Roofing
AaronB's Avatar
Remove the shingles and check the roof deck. Cances are the roof deck is also water damaged. Replace as necessary.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Counter flashing where roof meets vertical brick wall sandyman720 Roofing/Siding 5 02-20-2011 11:13 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
