Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-18-2012, 08:33 AM   #1
roof shingles over or under gutter hangers?
I'm in the process of having my roof reshingled. The roofer has removed the old shingles but left the gutter hangers, which were nailed through the top of the shingles, in place. The hangers are called Roof Rafter Tail Rod & Nut Gutter Hangers. It's the type that's designed to be nailed down through the shingles. Yesterday he began laying ice and water shield over the hangers. This has left a noticeable gap on either side of the hangers and I can easily see that the ice and water shield is not laying flat against the roof plywood on either side of the hangers. My concern is that it never will, and water will work it's way up the roof from ice dams that occur every winter. Am I right? Should I ask him to pull up the ice and water, removed the gutter hangers and install them over the shingles?
craigwc is offline   Reply With Quote
Old 10-18-2012, 09:45 AM   #2
Hangers that are attached on top of the shingles
Sounds like a sure way for a roof leak to me.
Got a picture?
I've seen the type that mount on the roof but there installed under the shingle not on top of them.
Trouble posting a picture? Pick one of these and cut and paste which one you have.
http://www.bing.com/images/search?q=...ypes&FORM=IGRE
mae-ling (10-18-2012)
Old 10-18-2012, 10:21 AM   #3
This is the type of hanger I have:
Old 10-18-2012, 10:21 AM   #4
Not used to that style
mae-ling is offline   Reply With Quote
Old 10-18-2012, 10:30 AM   #5
It's suppost to be attached under the shingle not on top of them.
Old 10-18-2012, 10:36 AM   #6
And under the ice and water shield too? Just can't see how the shield will adhere flat to the plywood with that round gutter hanger holding it up.
Old 10-18-2012, 10:41 AM   #7
If it was my job I would have removed the gutters, layed down the Storm and Ice Installed the gutter, sealed over the fastners with silicone then shingled over the brackets.
I'm sure some of the full time roofers will be along sometime.
We only did about 10 roofs a year, most on 100 plus year old houses. Lots of them had that style gutter hanger and I've never had a call back about a leak.
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing 4 10-24-2010 02:18 PM
1/12 sloped roof leaking w/ asphalt shingles, replacement ideas? Tuffguy610 Roofing 3 03-17-2010 06:59 AM
Patio Flat Rubber Roof installed, and gutter cleaning - ripped off? mark2741 Roofing 17 03-08-2010 12:55 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
