Roof Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2010, 01:43 PM   #1
Roof Shingles
I'm going to have my house re-roofed. I've narrowed my my shingle choices to GAF and IKO. I've read both good and bad recommendations on both. Your thoughts will be appeciated
A Coda is offline   Reply With Quote
Old 04-28-2010, 04:37 PM   #2
Gaf for sure,IMO.
johnk is offline   Reply With Quote
The Following User Says Thank You to johnk For This Useful Post:
A Coda (05-03-2010)
Old 04-28-2010, 07:49 PM   #3
Residential Roofer
Slyfox's Avatar
So far this year I have installed Gaf/Elk, OC, IKO, Tamko and am getting ready to start a home using Certainteed.
The right roofing contractor makes all the difference.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
A Coda (05-03-2010)
Old 04-28-2010, 10:58 PM   #4
Commercial Roofing
AaronB's Avatar
I always pick between GAF and Elk
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
The Following User Says Thank You to AaronB For This Useful Post:
A Coda (05-03-2010)
Old 04-29-2010, 12:16 AM   #5
??What you talking bout Willis?They are the same company still,right?
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 09:46 PM
Epoxy roof sealant over shingles? P550 Roofing/Siding 15 04-11-2009 11:00 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 11:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
