Roof Sheathing Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-07-2008, 06:47 PM   #1
I had new architectural shingles installed 5 years ago and now I have noticed a problem in one section of the roof. I noticed a slight bulge in the roof line and after climbing up to investigate found one of the 4ft. sides on one sheet of sheathing is coming loose from the rafters. I know all the seams were checked before the new shingles were installed because it was a complete tear off and reroof done by a reputable contractor.
My question is whether this can be easily repaired or am I looking at a major repair bill??
Thanks for the advice!!
golfman1867 is offline   Reply With Quote
Old 07-07-2008, 10:15 PM   #2
Doing This Way Too Long
Rewards Points: 532
If no other problems found when it's torn up, it's just a matter of tearing off the area, fixing or replacing the sheeting, and patching it up. Few bundles, some felt and maybe sheeting. Chance the shingles won't exactly match.
Gotta wonder why it did it though, and if it's just a symptom of a bigger problem.
That fix, in itself, isn't that major of an issue. Maybe four hrs labor and a hundred dollars in material.
OldNBroken is offline   Reply With Quote
Old 07-07-2008, 10:57 PM   #3
Registered User
Termite's Avatar
Even the most reputable contractor can miss a rafter with a few shots from a nail gun. And, even the most reputable contractors typically have at least one idiot on the crew!
Chances are it is an isolated problem on what is otherwise a good installation.
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 01:02 AM
roof sheathing placement dmend Roofing/Siding 1 03-20-2006 09:03 PM
