Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 03-20-2006, 02:44 PM   #1
roof sheathing placement
My first time at this forum (just found it). Looks like a great information resource. I'm building a 2-car garage, gable roof. Looked at many framing books but not much is said about roof sheathing.
Does the roof sheathing overhang or is it flush with the barge rafter?
Should the sheathing be uptight against each other or should there be some space between the 4x8s?
Thanks,
dmend
dmend is offline   Reply With Quote
Old 03-20-2006, 10:03 PM   #2
MJW
Nail some 16D nails on the rafters between the sheets when installing them. This should give enough space between them. You don't want them tight. Make sure to remove the nails before you trip on them. The sheathing should not overhang the roof at any point. Have it flush or close to flush to the edge and gable end fly rafters. Use style D roof edge before installing any roofing, unless you are having a wood fascia.
MJW is offline   Reply With Quote
Uneven sheathing on new construction roof mjw930 Roofing/Siding 28 04-10-2007 10:51 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Roof sheathing at the peak dmend Carpentry 2 04-14-2006 04:17 PM
warped roof sheathing arizonahiker Roofing/Siding 13 11-17-2005 01:53 AM
Roof Sheathing Acceptable Tolerances? claypj Roofing/Siding 2 08-15-2005 04:16 PM
