Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-19-2009, 09:54 PM   #1
roof sheathing with felt atached
hi, im in the process of building a house and was told by somebody about a new product, a roof sheathing with a felt paper like product already attached. anybody heard of it ???
roadhouse is offline   Reply With Quote
Old 07-20-2009, 06:17 PM   #2
I've heard of Zip Roof. It has a water resistant layer bonded to OSB and doesn't require felt paper under the first roof. It still requires felt paper for subsequent roofs. It also gives you immediate dry-in because you tape the joints and it can be left exposed (after taping) for quite a while which is good for DIYers that might take a while getting shingles on.
Downside is cost. Expect to pay quite a bit more than OSB and a little more than plywood. The tape is pretty pricy.
New roof and Sheathing - Install new fascia before or after? hartkem Roofing 2 06-01-2009 01:12 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
