| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Avoid Tornado Damage
by eHow.com
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
How to Fasten Metal Tile Roofs
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
How to Measure for Bend & Cut Points in Metal Roofing
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Measurements are taken top and bottom for each piece. Each installer has its own preferred spot on the panel to use as a con base point to measure from... Read More »
How to Install Wood Shake Tile Roofing
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The profile over the wood shake panel is comprised of a 4 inch low 6 inch high 8 inch low and a 6 inch high pattern. Each full panel has a two pattern... Read More »
How to Draw a Haunted House
by eHow.com
Starting with a basic house, you can easily turn your drawing into a spooky haunted house. Even if you don't think you draw well, you can incorporate some basic and simple elements into your picture to give it that creepy feeling you want. Read More »
