Roof Sheathing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-12-2013, 03:14 PM   #1
Rewards Points: 396
Roof sheathing
Hi,
Can someone tell me the proper way to install sheathing at the very peak of the roof? Do you overlap the edge of one sheet over the other side or just meet both sheets at the very top?
detroittigerfan is offline   Reply With Quote
Old 10-12-2013, 03:48 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,940
Depends on how the roof is framed, venting, etc.
Old 10-12-2013, 03:48 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
do you have a ridge vent?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-12-2013, 05:51 PM   #4
Rewards Points: 396
No no ridge vent. At what point do I stop the sheathing when I get to the very peak is what I am asking.
Old 10-12-2013, 06:02 PM   #5
Rewards Points: 13,300
Big mistake to not have a ridge vent but just having them meet at the peak with no over lap or even leaving them a little short is what I would do.
The plywood needs room to expand and contract.
Old 10-12-2013, 06:11 PM   #6
GBrackins's Avatar
like joe said
Gary
Old 10-12-2013, 07:38 PM   #7
Rewards Points: 396
like joe said
I might install a ridge vent yes. I have a truss roof. From what I read on the directions I need to make a 3/4" cut from each side of the truss peak which would give 1.5" of open air space for the vent. Sound about right? I know some manufacturers might have different directions but from the one I found that is what they suggested. When you need to join 2 pieces of ridge vent do you simply but them up together and caulk the seam?
Old 10-12-2013, 08:09 PM   #8
kwikfishron's Avatar
Rewards Points: 186
Do you have eave vents? Without them the ridge vent is worthless.
kwikfishron is online now   Reply With Quote
Old 10-12-2013, 08:27 PM   #9
747
registered
747's Avatar
Rewards Points: 534
i'm not a fan of ridge vents in a snow state. I like metal louvers sloped on front. No snow no problem. When sheathing you want to leave a small gap on all sheets where they meet. About the size of a good size framing nail should do it. This allows for expansion so the roof won't buckle.
747 is offline   Reply With Quote
Old 10-12-2013, 08:34 PM   #10
Rewards Points: 2,238
If you are going to use ridge-vent -
most ridge-vents are continuous or in sections (with transition, joiners)
No soffit vents?? (in the eaves) - not good!
rossfingal is offline   Reply With Quote
Old 10-13-2013, 08:53 AM   #11
Rewards Points: 396
Yes there is soffit vents.
Old 10-13-2013, 09:39 AM   #12
Rewards Points: 396
The ridge vent I am going to use is in 2 sections. No transition. Do I simply but the ends together and caulk the seam?
Old 10-13-2013, 10:11 AM   #13
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Metal? Lap them 6" with a bit of caulk inside the lap, hidden from the elements.
Mesh or otherwise being covered by cap? Butt the sections.
Nobody mentioned it and it might be moot. The sheathing must reach the peak if NO RV is being used. 1-1/2" short to 2" short WITH RV being used. It's subject to the width of the ridgeboard with 3/4" opening to each side being minimum.
tinner666 is offline   Reply With Quote
Old 10-13-2013, 11:22 AM   #14
Rewards Points: 396
No they are plastic ridge vents and without ridge vents do you simply meet the sheathing on each side to a a point where they just touch the ridge board or truss peak?
Old 10-13-2013, 11:29 AM   #15
Pro Slate Roofer
tinner666's Avatar
To apeak. Otherwise, a flat spot will exist and the shingles will lie flat. Shingles lying flat leak.
Sheathing for concrete tile roof? RM575 Roofing/Siding 3 08-04-2013 11:03 PM
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 10:40 AM
Roof Sheathing mrus Roofing/Siding 8 04-07-2012 07:59 PM
Roof Sheathing Thickness Clutchcargo Building & Construction 8 09-23-2009 02:13 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
