Roof Sarking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-06-2009, 03:23 AM   #1
Roof Sarking
I am building a pergola with a 20 deg pitched roof, I have decided to use sarking to keep it cooler.
I know the blue side faces up but Im not sure if the sarking goes on top of battens or under. I have already put battens in. I have done this sort of thing before but it was over 15 years ago and I just can't remember..
Salvtore
SALVTORE MUSUME is offline   Reply With Quote
Old 01-06-2009, 07:34 AM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
Sarking ????-I`m taking a stab here,but are you referring to "SHARKSKIN"underlayment,If you are the underlayment does go on before the battens
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-06-2009, 08:06 AM   #3
roofing
I was afraid of that.
thanks
Old 01-06-2009, 08:07 AM   #4
you`re welcome
Old 01-08-2009, 01:25 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
that was a nice stab god
Tom Struble is offline   Reply With Quote
Old 01-08-2009, 10:18 PM   #6
Commercial Roofing
AaronB's Avatar
MikeNZ referred to sarking as, I believe, Skip sheathing.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-11-2009, 06:39 PM   #7
Rewards Points: 150
sarking ? thats gottta be a new one. no comprenda
RooferJim is offline   Reply With Quote
Old 01-15-2009, 06:46 AM   #8
I saw that too Aaron,The guy miss-spelled sharkskin is all,or couldn`t remember the right word,the blue color he described was a tip off
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Roof sarking Owen Roofing/Siding 4 01-11-2007 09:14 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
