Roof For Room Addition - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 07:01 PM   #1
roof for room addition
Ok I'm brand new to the site so bear with me. Here goes... I have a two story house with a hip roof in southeast ga. I am adding on to the back corner of the first story to expand the kitchen/dining room. It will be an 11x17 foot addition with an 8ft ceiling to match existing ceiling. I am trying to determine the best type of roof to go with. A shed roof is out because it would run into the windows on the second floor. I could go with a gable but am wondering if a hip roof would match the house better. Thoughts, suggestions, and/or links to resources are welcome.
Also how do I tie in to the house? Everything I've found online covers tying in to the existing roofing such as with a single story home or a 2 story addition.
Also I will be using a beam to span the 17 ft distance where the exterior (load bearing) wall currently is. What size beam should this be? I know it will have to be beefy due to the span and since it also supports the second floor. Again any help is much appreciated.
hand_in_ga is offline   Reply With Quote
Old 06-05-2012, 08:22 PM   #2
DIY staff
Rewards Points: 7,174
An engineer will need to spec that beam for you--- Likely a lam beam---but the size needs to be determined by the load above--
Roof lines---when possible--it is always best to make the roofing style match the roof of the existing structure---a well designed addition should look like it was always part of the original home.
hand_in_ga (06-06-2012)
Old 06-05-2012, 09:30 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Once you get the addition engineered, you will then know what kind of roof will work.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Old 06-06-2012, 12:26 PM   #4
Thanks for the replies so far. Any additional suggestions, pointers, etc. are welcome.
Old 06-06-2012, 02:01 PM   #5
Pro Slate Roofer
tinner666's Avatar
Not at this point. Pix and diagrams would elicit more replies now.
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Help with roof line on addition cen Roofing/Siding 0 10-24-2010 11:35 AM
Help with roof framing addition gregsmy Building & Construction 0 08-19-2010 08:43 AM
joining new roof addition to existing roof?? roper21 Roofing/Siding 2 04-14-2009 10:22 PM
