Roof Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-27-2011, 05:05 PM   #1
Question
roof ridge vent
How long have they been out. How good are they?
honeydu is offline   Reply With Quote
Old 02-27-2011, 05:30 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
out where?
Tom Struble is offline   Reply With Quote
Old 02-28-2011, 10:09 AM   #3
old timer
We've been installing them since the 70's.
dmc@RCR is offline   Reply With Quote
Old 02-28-2011, 12:14 PM   #4
Solutions (handyman)
Rewards Points: 364
Ridge Vents
They've been around for some time and when I built (two years ago) I did some research about pros & cons. I installed a roof ridge vent because it made sense to have venting the total length of the house rather than specific areas. The other vents will work, so the primarey consideration is to ensure that you have enough venting for the square footage of your building.
Mark Harvey is offline   Reply With Quote
Old 02-28-2011, 02:47 PM   #5
Residential Roofer
Slyfox's Avatar
Metal Exposed ridge vents were already around when I started roofing in 79, the cap over version didn't come out in my area until the late 80's early 90's and didn't become common place until the late 90's.
Some roof designs with very little ridge "hipped roof" normally require a combination of the two, ridge vents where possible and pot/turtle vents where there is not enough ridge.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 03-02-2011, 03:33 PM   #6
As stated, various forms of ridge vents have been around for decades.
The most important features that the actual ridge vent product should contain are an external wind deflecting baffle to prevent air entry into an exhaust vent product and an internal filter to prevent powdrery snow or excessive external humidity from gaining entry into the attic, catching it and then alowing the exhaust vent flowage to evaporate and expell it.
Further, for ANY Exhaust Ventilation product to operate as designed for maximum efficiency, there Must be the correct amount of net free square inches of Intake Ventilation as determined by each individual homes attic floor space calculations.
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-11-2011, 03:55 PM   #7
I would only use a ridge vent if I had to do so because of the need to ventilate boxed in chanels like you commonly see in some cathedral style roofs. I really can't see any advantage for them in open attic spaces and they cost more than regular vents.
lucknow is offline   Reply With Quote
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 03:47 PM
Vent a Hip Roof albasaurus Roofing/Siding 7 08-11-2010 11:48 AM
Ridge roof ventilation rbdaniel33 Off Topic 1 06-02-2010 08:24 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
