Roof Repair.. It's Leaking....BAD - Roofing/Siding - DIY Home Improvement | DIYChatroom
Poll: How many times have you accidently fallen off a roof?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Poll Options
Old 09-19-2011, 02:54 PM   #1
Question
Roof Repair.. It's leaking....BAD
Hi. My back porch is a freaking mess. It just started with a drip and now with all this rain, there are like 50 drips going on. I ripped the ceiling apart so I could contain the water better and it helped, but I need to fix this problem and unfortunately hire someone. (My dad thinks I'll fall off the ladder or something and he's probably right if a bee lands on me or something.)
How much do you think it would cost for repair for the 2x4 pieces of wood, shingles ect, & labor for an area around the size of 5' X 13'?? Any Ideas
I think it's going to rain today. I'd be lost without my shop vac!
ILOVECAKE is offline   Reply With Quote
Old 09-19-2011, 06:06 PM   #2
Unhappy
Why so many views (over 70) of the post and no replies ??? I don't get it
Old 09-19-2011, 06:10 PM   #3
Framing Contractor
Rewards Points: 120
a picture would help. Best advice is to call a couple of roofing contractors that specialize in repair work.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
ILOVECAKE (09-19-2011)
Old 09-19-2011, 06:32 PM   #4
Smile
not a problem. Glad someone let me know. THANK YOU
Old 09-19-2011, 06:41 PM   #5
Pictures of the Ceiling Where it's Leaking
It's not pretty. But here it is.
The 1st picture just gives you a frame of reference of the size of the area from a distance.
2nd pic is the rotted wood that needs replacement. It's like this, but not as bad the full width of the porch.
Basically, my porch is a royal pain in my @$$
Roof Repair.. It's leaking....BAD-imag0915.jpg   Roof Repair.. It's leaking....BAD-imag0910.jpg
Old 09-19-2011, 07:11 PM   #6
Framing Contractor
Rewards Points: 120
Not looking good. Appears that leak has been there for quite a while. I imagine a lot of wood will be replaced there.
Old 09-19-2011, 07:37 PM   #7
MJW
Not to mention that it appears there may be lead paint there. Make sure you use an EPA certified firm to work on any of that.
BTW, I have fallen from a roof and I am a pro. Broke my leg and crushed a vertebrae in my back. Luckily I was only 24 when it happened (now 32) and I healed very well. Took about 8 months of rehabilitation.
MJW is offline   Reply With Quote
Old 09-19-2011, 07:41 PM   #8
MJW
Just read your intro. DIY'ers are exempt to the lead based paint rule, but landlords are not. Make sure you follow guidelines or get a pro so you aren't in a court room over this.
Old 09-20-2011, 11:39 AM   #9
OMG, you fell! That's why, I'd rather have someone else get up there. I will attempt almost anything myself, but no way am I confident enough to attack that.
Old 09-20-2011, 06:23 PM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I ddin't fit in the poll. I've fallen numerous times and still roof instead of talk roofing. I have more 'Air-Time' than Walter Cronkite.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
MJW (09-20-2011)
Old 09-22-2011, 01:03 AM   #11
Talking
HAHAHA & your still walking? You must be made of steel!
Old 09-22-2011, 01:19 AM   #12
All homes built prior to 1978 I think have lead paint in the house some where. As long as it's concealed/ painted over and not scrapping and sanding the stuff. The house is safe. Same goes with Asbestos. As long as you don't start tearing it apart; making the asbestos easy to inhale and harm you, it's fine.
Old 10-12-2011, 09:27 PM   #13
Exclamation
Got roof fixed... You'll never believe.......
the damage was from. TERMITES!!!! AHHHHHH Nasty things. Funny thing is that I never saw one ant on that porch. the guy that did the repairs said that the termites probably started the damage and the weather and more termites made the roof in the condition it was in.
Does anyone know how to prevent the termites around my house?
I have freaking carpenter bees that like to live inside the wood of my front porch railing. Filling the holes they make with caulk in the evening actually stopped them from nesting in the wood. But those mofos are freaking large and i'm outta there when they are flying around and tying to take over the porch. those bastards... I hope I dont encounter any more issues with things that crawl and eat wood... eeeeek
Old 10-12-2011, 09:35 PM   #14
Rewards Points: 956
lol thats awesome.
federer is offline   Reply With Quote
Old 10-12-2011, 09:37 PM   #15
Rewards Points: 956
i myself have been up on the roof quite a few times now since we had to replace the entire roof last year and we just got a vent installed and fortunately no falls yet. i did slip a little bit but it was only a skin scrape. my roof is not normal though. 50% flat 50% shingle
Tags
roof leak , roof worker needed , shingle replacement , wood replacement
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Repair and Maintence of a Torch down roof. superdairyboy Roofing/Siding 12 03-29-2011 10:24 PM
Tied in Porch Roof to Existing Roof - Leaking bharling Roofing/Siding 29 03-08-2011 05:06 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Supposedly 'new' roof is leaking beejay Roofing/Siding 3 03-06-2007 10:55 AM
