Roof Relly Sagging - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2007, 02:50 PM   #1
roof relly sagging
Hello, Im a first timer to this site! My question is, I have a roof that is sagging by about 3 inches. This is a very old roof but in good condition other than the sag. Right now it looks like about 32inch between rafters (rafters 3 in.x5in.) with one cross piece runnin a span approx. 10 feet to other rafter.It has no knee wall or anything.Would it be possible to jack the rafters up ,and then build a knee wall to support.The ceiling joists are 2 in. by 7 in. on 16 in. centres(really old wood). What do I do please help Thanks
farmer7 is offline   Reply With Quote
Old 08-24-2007, 03:14 PM   #2
Is the decking sagging or is it the rafters?
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-26-2007, 11:19 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
you may want to install cat`s between the rafter space,need pics to properly see what`s up,sounds like you had a shake roof ,and they removed the purlins prior to resheathing??
the roofing god is offline   Reply With Quote
Old 10-22-2007, 11:36 AM   #4
Hi. I have a sagging roof over a 3-car garage area. There are no wall supports under this area, but the adjacent kitchen, living @ dining area do have interior walls but no sagging roof over these areas. Some of the trusses over the garage have pulled apart at the between spreader supports.
If I jack up the ceiling in the garage and reconnect the supports will this correct the valleys on each side of the peak, and solve the problem so I can remove the jacks?
Binker is offline   Reply With Quote
Old 10-22-2007, 01:10 PM   #5
Binker & Farmer7,
Diagram and post photos. Time to address the problems you both advise may be when you are ready to re-roof. Framer7 do you have a ridge board? It doesnt sound like it.
Big Bob is offline   Reply With Quote
Old 10-22-2007, 05:52 PM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Need a lot of detailed pics. And you can't just install kneewalls without proprer support for them. It might need an engineer.
tinner666 is offline   Reply With Quote
Old 10-22-2007, 06:09 PM   #7
Did somebody remove collar ties for previous work?
send_it_all is offline   Reply With Quote
Old 10-22-2007, 09:37 PM   #8
we like pics
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
Sagging roof Haney1 Roofing/Siding 23 10-23-2012 10:04 AM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
fixing a sagging porch roof vhowler Roofing/Siding 2 05-11-2006 07:53 PM
