Roof Rebuild Q's - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-30-2012, 08:41 PM   #1
Question
Roof Rebuild Q's
Hello everyone. Before I purchased my house there was a sun room addition that was built onto it with a flat roof. Just recently, the roof started to leak through into my sun room. I really dislike the concept of having a roof with virtually no pitch, so I've decided to rebuild a better, pitched roof in its place. My issue is how to lay it out.
I'm going to attach a couple images I made that show both an aerial and side view of the roof in question. Please excuse my amateur paint skills!
Should I attach a ridge board to the wall underneath the window and run rafters from it? Do I need to place something underneath the ridge board so it can hold the weight of the rafters? How big do the rafters and ridge board have to be? I figured 2x6 for the rafters since it appears to be standard, but I don't know how to gauge the ridge board size. I've tried my best to research about roofing, but I have virtually no hands on experience with it so it's hard to visualize everything.
Any help with this would be greatly appreciated!
aschmidt is offline   Reply With Quote
Old 08-30-2012, 11:11 PM   #2
Rewards Points: 14,294
There is no "standard" size for rafters. The width used is determined by the span, the longer the span the wider the joist used.
For a shallow pitched roof like your's all you would need is the next wider size for a ledger. EG 2 X6 rafter, use a 2 X 8 ledger.
That roof is going to need to sit about 6" below the windows to allow room for flashing and reduce splash back on the windows.
It's always best to have some over hang on the lower end of the roof.
I'd strongly suggest at least getting a contractor to dry this in for you if you have never cut rafters before. If it's done wrong you back to square one again.
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
