Roof Rafter Rot Fix - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-18-2011, 09:05 AM   #1
roof rafter rot fix
Fixing up my camp shack, question about the roof.
As you can see in the pictures, I have about 3 rafters with some rot and a couple of pieces of the roofing wood itself with some rot.
How can I go about fixing this/stabilizing this without tearing up the entire roof?
I was thinking maybe run another piece of wood directly along/attached to the portion of good rafter on the rafters that have rot as the entire rafter is not rotted just sections.
Keep in mind this is just my camp shack - no water, electricity. I don't want to go crazy just maybe stabilize it better. The roof is actually pretty solid - I can walk on it (though I did not try to walk over the areas where the rafter rot are) and it does not leak.
thanks
roof rafter rot fix-dscn2477.jpg   roof rafter rot fix-dscn2478.jpg   roof rafter rot fix-dscn2468.jpg
snosurfa7 is offline   Reply With Quote
Old 05-18-2011, 10:14 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
thanks
No bigger than that is I would cut some decking to go on the underside and sister rafters beside the bad ones, I would cut the tail of the new rafter to sit on top of the ceiling joist there at the top plate. I would scab the rafter next to the new one to hold up the decking the sister on the other side so the tail could sit on the ceiling joist. That looks like oak rafters and decking so it may be kinda hard to nail.
Just had another thought, if the roofing nails go through the bottom of the decking, be sure to bend them over or cut them off before putting the new decking up under there or you will have new leaks from the nails being pushed up into the roofing.
I bet that place is cold and the walls sweat in the winter.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-19-2011, 06:26 AM   #3
Thanks for the reply. I'll give that a try.
Have not stayed there in the winter yet, just 3 seasons - cinder block is actually quite comfortable in the summer, cooler than a stick built shack. Need to line the chimney and put a wood stove in there (which it used to have at one time) but I want to get the roof around the chimney up to par before I do this...
thanks!
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
