Roof Problems - Warped Boards. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 05:09 PM   #1
Roof problems - warped boards.
I noticed some discolouration on my ceiling so I went into the crawl space attic to have a look. It seems the boards have begun to warp as shown in the attached photos and the water was dripping. I haven't gone up to the roof yet as it is still raining pretty hard.
What are my steps from here?
Thank in advance,
John
Roof problems - warped boards.-img_1892.jpg   Roof problems - warped boards.-img_1888.jpg
John84 is offline   Reply With Quote
Old 06-23-2013, 05:29 PM   #2
Rewards Points: 6,652
This is what happens, when builders use the cheapest subs, along with improper venting in the attic.
The Following User Says Thank You to gregzoll For This Useful Post:
Gymschu (06-24-2013)
Old 06-23-2013, 05:41 PM   #3
Rewards Points: 13,694
All the shingles, tar paper, and sheathings going to need to be replaced.
Mostly because someone did not spend the extra $20.00 for the H clips.
I'd guess the shingles have leaking for a long time to have cause this to happen.
http://www.bing.com/images/search?q=...electedIndex=2
Old 06-23-2013, 06:09 PM   #4
Roofmaster
Rewards Points: 2,210
Which came first, the hole or the warped sheathing? I suspect the former?
Old 06-23-2013, 08:09 PM   #5
Metal Roofing
Rewards Points: 600
Can you post some roof pics also.
AndyWRS is offline   Reply With Quote
Old 06-23-2013, 08:16 PM   #6
Thanks for the responses so far. I was going to make it up to the roof after the rain stopped but it persists.
Old 06-23-2013, 08:42 PM   #7
kwikfishron's Avatar
Rewards Points: 576
Looks like 3 ply 3/8" to me. Are there any grade stamps on the plywood?
kwikfishron is online now   Reply With Quote
Old 06-24-2013, 08:49 PM   #8
So I finally got up on the roof after work today. Pics posted. That's scotch tape on top of the nail on the third picture. I'm assuming that was a band aid fix for something.
I didn't see any grade stamps on the boards, no.
Roof problems - warped boards.-img_1893.jpg   Roof problems - warped boards.-img_1894.jpg   Roof problems - warped boards.-img_1895.jpg   Roof problems - warped boards.-img_1897.jpg   Roof problems - warped boards.-img_1898.jpg
Old 06-24-2013, 09:24 PM   #9
Those shingles should have been replaced long ago.
Old 06-24-2013, 09:43 PM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I'd suspect finding more damage elsewhere when you get that roof torn off in preperation for the new one. There is no hope of fixing that. That roof is long past shot.
tinner666 is offline   Reply With Quote
Old 06-24-2013, 09:50 PM   #11
Doing This Way Too Long
Rewards Points: 532
I think the general consensus here will be "That roof is shot". Sorry
OldNBroken is offline   Reply With Quote
Old 06-24-2013, 10:18 PM   #12
Not scotch tape, but the mylar that is placed where the blackjack that is on the back of the shingle, to keep them from sticking.
Old 06-25-2013, 06:08 AM   #13
Okay, thanks everyone.
Roof problems - please help Michelle Roofing/Siding 14 06-15-2016 06:55 AM
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 10:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof Problems!!! clockwork1 Roofing/Siding 4 08-19-2005 09:31 PM
Roof problems :( Help!!!! Warped Roofing/Siding 5 05-29-2005 07:06 PM
