Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 11-26-2009, 11:08 PM   #1
which roof plane drains the highest volume of water?
I have 2 questions, and this may seem brutally obvious to all of you, but
1. Which one of these roof planes drains the highest volume of water? Looking at the drawing below, original blue roof is 4/12 pitch and is about 55 feet long, the shingled portion (my porch add on) is 2.25/12 and 40x20 ft the Pink roof is 4/12 and 22x20 ft. My guess is the 4/12 garage will move the highest volume of water and I should shingle the 2.25/12 pitch first, and cut the garage shingles 2" from valley center. Am I correct?
2. If I do a closed cut valley, should I start shingling from the rake into the valley, or shingle OUT of the valley? How do I determine that I won't end up with 1/4 of a shingle at either end?
Thanks in advance for any and all help!
my5sons is offline   Reply With Quote
Old 11-27-2009, 07:57 AM   #2
Pro Slate Roofer
tinner666's Avatar
I prefer to shingle out of the valley. Using dimensional shingles, you don't have to worry too much about the ends, but it can bite you. Here and there near the edge, you might have to piece in some 12" - 28" pcs.
A 1/4 shingle isnt too small to use. I've used 6" when necessary.
Not sure which plane as drawn will have the most water, It looks like the original roof will to me. I notice the ridge is above the valley top there. Run it under never less than 14", and cut the other side 2" from center. I like to taper the cut from 2" at top to 3" on bottom.
Frank
tinner666 is offline   Reply With Quote
Old 11-27-2009, 09:26 AM   #3
If you do a closed valley, follow what tinner says but instead of having to worry about that, why dont you do an open metal valley?
Are you using dimensional or 3-tab shingles?
BamBamm5144 is offline   Reply With Quote
Old 11-27-2009, 08:41 PM   #4
Pro Slate Roofer
tinner666's Avatar
Open valleys are nice too. One creavat: You have to cut the shingles ends off properly. BTE, you have to do that either way! I forgot to mention it earlier.
which roof plane drains the highest volume of water?-unclipped-shingle-damage.jpg
Frank
Old 11-27-2009, 08:47 PM   #5
Pro Slate Roofer
tinner666's Avatar
These pics show the correct way. The picture I posted just before, is what happens when the tops aren't clipped.
which roof plane drains the highest volume of water?-pipe-valley-.jpg   which roof plane drains the highest volume of water?-untitled-4.jpg   which roof plane drains the highest volume of water?-clipped-top.jpg
Frank
Old 12-01-2009, 05:38 PM   #6
I am using Timberline 30 Laminated Shingles. I think they call them architectural. I thought about a metal valley, but not sure where I order one from. I'll be ready to shingle this weekend again. There was a lot of stuff I would have done differently if I had to do it all over again. In the meantime, it is what it is...
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
