Roof Penatration Size? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-23-2010, 11:26 PM   #1
Roof penatration size?
I am going to open some holes on the flat roof before I call my roofer to start the re-roofing project.
1. Kitchen extractor pipe.
2. (2) bathroom fans outlet
What are the usual sizes of these two kind of opening?
Thanks!
pttcc is offline   Reply With Quote
Old 08-24-2010, 12:17 AM   #2
Doing This Way Too Long
Rewards Points: 532
Large enough to run your ducting through. The flange of the roof flashing will cover a much larger area than the actual vent size so don't be afraid to go an inch or two oversized.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
pttcc (09-16-2010)
Old 08-24-2010, 04:45 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks!
What sizes are the outlets on the units? Kitchen fans vary widely. Bath fans are usually 3" or 4".
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
pttcc (09-16-2010)
Old 08-24-2010, 09:08 AM   #4
Our new range hood recommends a minimum of a 6in. diameter duct.
cbaileyau is offline   Reply With Quote
The Following User Says Thank You to cbaileyau For This Useful Post:
pttcc (09-16-2010)
Old 08-24-2010, 05:11 PM   #5
Rewards Points: 532
then an 8" hole would do nicely.
Old 08-28-2010, 11:23 PM   #6
Rewards Points: 956
how do you find out where the ducts run to?
federer is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 08:32 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Chimney roof penitration size? will52100 HVAC 16 08-28-2009 03:42 PM
