Roof Paint/UV Reflector - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-11-2007, 10:08 AM   #1
Hi,
I want to reduce the heat transfer from my roof into the 2nd story of my house. I have a dormer on the back of the house that has enough pitch to allow 90lb. rolled asphalt roofing material. I've heard of several companies that make a paint or "coating" specifically for this job. It's a white paint that reflects most of the heat/UV from the sun. I'm wondering if anyone here has any knowledge or experience with this. It seems to be somewhat common in the south ( Calif. ,Fla. Ariz.) but I live in Ohio and all of the roofing supply houses I've talked to think I'm a kook for wanting to paint my roof white...
Thanks for any advice/input
Nikonf32 is offline   Reply With Quote
Old 05-11-2007, 10:14 AM   #2
The generic product name you are seeking is an "elastomeric roof coating", which still needs to be re-coated every several years in most cases.
Some of the product have a supposed longer life cycle, and are even a complete roofing system in conjunction with a reinforcement mesh membrane.
Aaron knows much more hands on knowledge about these products than I do, so see if he checks in for more information.
Ed the Roofer is offline   Reply With Quote
Old 05-11-2007, 11:12 AM   #3
Thanks Ed..Different stuff
Thanks for the quick response!
I am pretty sure that the stuff I'm lookin' for is not the elastomeric stuff. I know that it's intended use is for flat roofs to waterproof them, but my roof is only 8 months old and does not leak at all. The paint I've heard of is made by the HENRY Co. in Calif. and is designed as a UV inhibitor/reflector and it's supposed to keep the house cooler inside.
Old 05-11-2007, 11:19 AM   #4
Since you already knew the name of the products manufacturer, you could have Googled it, so I did it for you.
Next, you need to contact them to see who carries the type of product they recommend for your application.
The white roof coatings are called "elastomeric" roof coatings by the way.
http://www.henry.com/Cool_Roof_Coatings.28.0.html
Ed
Old 05-11-2007, 12:36 PM   #5
Thanks again
Ed,
Thanks again! I shoulda thought of that 1st...I went to the link and it answered my questions... I had a different idea of what elastomeric products did....I've always thought they were used on rubber roofs..
have a good weekend!
Old 05-12-2007, 06:28 AM   #6
Commercial Roofing
AaronB's Avatar
Well, that was easy.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-12-2007, 10:43 AM   #7
Thanks Aaron. I couldn't have done it without you!
I do know that you have much more experience in that particular area of expertice.
Ed
BTW, Is Grumpy in contact with you? I haven't seen hide nor hair of his postings for about a month? I hope its because he is just too busy with moving into the new office and new work load.
Old 05-12-2007, 02:53 PM   #8
Commercial Roofing
AaronB's Avatar
I hear from him every couple of weeks or so.
He seems to be working pretty steadily.
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
