Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-07-2013, 03:33 PM   #1
Unhappy
Roof over patio with a U-shaped house!
I have a U-shaped house, courtyard in the middle (concrete). Roof on all three sides angled into courtyard. I want to put a roof over it. How can I do this without it getting cramped or dark? Easiest is straight off the roof, but then the height is really low. Any suggestions or links?
TRISTRAM is offline   Reply With Quote
Old 02-07-2013, 05:16 PM   #2
STAFF
BigJim's Avatar
Good gutters and raise the roof on the patio a foot or two to let light in and give more height. JMHO
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 02-07-2013, 05:37 PM   #3
Shed style roof that's ran all the way to the peak of the center section.
There is no way to keep the other rooms from getting darker unless you add some sky lights to the new roof.
Old 02-07-2013, 08:51 PM   #4
Pro Slate Roofer
tinner666's Avatar
I'd set it on posts, detached from the house, and raised about 3" above the gutters on the house, AND I'd canterlever it two-three foot across the existing house roof on all three sides. Make sure the gutters and roof areas can all be accessed for replacement or repairs in the future. Shingle roofs need to be replaced every 20 years or so.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
BigJim (02-07-2013)
Tags
roof, roof angle, roof deck
1930s stone / shingle house with slate roof s_ny10023 Remodeling 1 04-05-2012 04:44 PM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
