Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-19-2005, 04:42 PM   #1
Roof over existing roof
I recentlly bought a new home where a family room and master bedroom were added on by the previous owners.
Well, where they tied in the new roof over the old it leaks.
I need to re-roof.
Can I simply re-roof over the existing roof or do I need to rip off the old roof and then re-roof?
Rammertime is offline   Reply With Quote
Old 01-28-2005, 10:21 PM   #2
Commercial Roofing
AaronB's Avatar
ALWAYS tear off. It is a far better job.
AaronB is offline   Reply With Quote
Old 02-01-2005, 01:58 AM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
It's always best to tear off a roof before installing a new roof. I know that some codes allow multiple layers but multiple layers make it hard to diagnose leaks. Also multiple layers don;t lay flat. Multiple layers don't last as long as single layers. Installing multiple layers prvents you from replacing damaged wood and identify other problems.
Tear off the old roof.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 05-03-2011, 05:27 AM   #4
It's better to just re-roof. It will save you problems later on when you need roof repairs.
Kristoph is offline   Reply With Quote
Old 05-03-2011, 06:16 AM   #5
Moderator
kwikfishron's Avatar
Welcome to the forum Rammertime.
You will likely also need to remove some siding where the additions roof meets the house to ensure proper flashing details, a step that might have been skipped when the addition was built.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 05-03-2011, 11:42 AM   #6
RFN-4A-LVN
Roofmaster417's Avatar
As it has been said the only way to insure that all damage decking,insulation etc, is to remove the existing shingles.Recovering a roof with saturated shingles(underpart),felt,decking and insulation is trapping the moisture and will IMO accelerated the rott,mold and all decaying aspects of your roof and interior.
But depending on your area pertaining to building codes and requirements you can recover the roof.
Is it advisable? Nope,,,,,it boils down to the fact of your finances.Yes its cheaper for a recover and you more than likely will stop the leak.But at what cost?
The cash you save by a recover IMO you should save and add to it for the future tear off and renovations needed to eliminate the mold issues.
Mold is extremely dangerous.It has very nasty effects on the body,,especially the respiratory system.I am in no way trying to scare you but I know people who have had relatives die from mold exposure from a saturated interior.
You could call 200 roofers and 50 of them will entertain your idea of a recover.I would be in that 50 too.The difference is I would be in the top 5 that would either talk you out of it or make some arraignments to help you afford the tear off.
Roofmaster417 is offline   Reply With Quote
Old 05-03-2011, 03:02 PM   #7
Shut in w/o Home
seeyou's Avatar
This is a thread from 2005.
seeyou is offline   Reply With Quote
Old 05-03-2011, 07:11 PM   #8
RFN-4A-LVN
I am a dope,hahahahahahahahahahahahahahahahahahahahaha
Old 05-03-2011, 07:16 PM   #9
RFN-4A-LVN
Well I wonder which he chose?,,,,,,,,,,,,,,,,,FNG's,,,,,,,1st post and he lures in a couple,,,Wow quickfish that puns for you.,..,.Is it possible to see a post from 05'?,,,,guess so,,,Kris must have had alot of time to kill.
Old 05-25-2011, 09:09 AM   #10
Well, this was useful to me so your response was not wasted!
Coach J is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 07:47 AM
Tying into existing roof Warren Roofing 2 05-06-2007 08:42 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
