Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-10-2010, 11:21 AM   #1
Roof mounting a pergola
I need some ideas for mounting a wood pergola to an asphalt roof. I'd like to mount a 2x6 parallel to the edge of the roof, about a foot up, that I can tie the crossmembers in to. Wondering if there was some sort of metal bracket that can be screwed into the rafters through the shingles that I can mount the 2x6 to. That being said, what's the best way to weatherproof the bracket/screws to ensure it doesn't leak?
tutt00 is offline   Reply With Quote
Old 07-10-2010, 02:52 PM   #2
Shut in w/o Home
seeyou's Avatar
You probably need to mount a post(s) through the roof to the framing and attach the 2x to it if I'm visualizing what you're up to correctly. There is off the shelf flashing for that sort of connection. It might be possible to surface mount the post after locating the framing. It would be flashed the same way.
seeyou is offline   Reply With Quote
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
