Roof Moisture Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-18-2009, 04:57 PM   #1
Roof moisture problem
I recently found a moisture problem in an unfinished attic space. The area is insulated with baffles between the insulation and roof. The roofing is intact. I recently had to replace the roof vent. I went from aluminum roof vent to the Air Vent Shingle Vent II from Lowe's. Now I find moisture on all the baffles. In one area it's even dripped onto the sidewalls. The attic area is heated. There was no condensation last year with the old roof vent. The only thing that's changed is the roof vent. Has any one else had problems like this?
K Faust is offline   Reply With Quote
Old 01-19-2009, 05:37 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It sounds as if you reduced the airflow. That's the only change in the system you mention.
tinner666 is offline   Reply With Quote
Old 01-23-2009, 01:11 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
Tinners right,There`s a big difference in volume,and mesh baffles in the shinglevent II that are meant to stop the water going thru
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-29-2009, 12:13 PM   #4
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Ridge vent won't work at all without equal or greater intake ventilation. However most mushroom vents, while work better with an intake, will still work somewhat without the intake. Is there an intake? In this space, how much insulation do you have? What is the architecure of the roof? It's not good to install a ridge vent on a hip roof, in most cases. Do you have a bathroom or kitchen vent dumping into the attic?
You say the attic space is heated? Am I to assume you have a furnace in the attic supplying heat to the rest of the house? Those are ALWAYS a problem in my experience, and require additional ventilation. What is the humidity level set at on the furnace? Is it possible there is a break somewhere in the duct pumping warm moist air into the attic? Have you sealed all the joints in the duct work with metal faced duct tape?
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 01-29-2009, 02:01 PM   #5
Hi K Faust,
Moisture in your roof is definitely not good. I would look into getting a professional roofer before the problem gets worse.
http://www.myprimebuyersguide.com/ca...ntractors.html
This is a list of roofing companies. Maybe it will help. Good luck.
caseyjones is offline   Reply With Quote
Old 02-02-2009, 09:01 AM   #6
Doing This Way Too Long
Rewards Points: 532
They have moisture in the attic and you are telling them to paint their roof.
SPAM
OldNBroken is offline   Reply With Quote
Old 02-14-2009, 12:08 AM   #7
The Spam Post and Poster have been deleted and banned.
Ed
Ed the Roofer is offline   Reply With Quote
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 03:50 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
