Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 03-10-2011, 05:41 PM   #1
WindowTreatment Installer
Roof leaking in warm weather only
One area of my roof the shingles meet alum. siding at 90 degrees. I'am getting a little water coming inside and dripping down the wall. This doesn't happen during the cold season, only in warm season. There is no flashing there. And if I did need flashing , not sure how to get it under the alum. siding without destroying it. Any suggestions on how to fix this.
bobtheblindguy is offline   Reply With Quote
Old 03-10-2011, 06:14 PM   #2
Experienced
Jackofall1's Avatar
Hello Bob, Does this happen only when it first warms up from the long winter?
What I am thinking is you have or should have, an ice dam, flashing under your shingles and behind you siding, if this is only happening now during the thaw chances are the ice buildup is going up the wal past the top of the flashing, when it melts it runs down and inside.
Mark
Old 03-10-2011, 06:43 PM   #3
Solutions (handyman)
I agree, it sounds like an ice jamb. I have to also ask, isn't there an overhang, ... where the roof line hangs over the walls? Even of a gable end there should be a little overhang. Just adding flashing probably won't solve theproblem, it would just slow it down some.
Another possibility is a leak in the shingles and if there isn't any felt paper or drip guard underneath, ... and there is a seam, this may also be the culprit.
Can to take a picture or two to show what and where the problem is?
Mark Harvey is offline   Reply With Quote
Brand new roof leaking over bulkhead pete0403 Roofing/Siding 10 01-10-2011 09:33 PM
big six profile roof leaking :( myhopper Roofing/Siding 7 11-03-2010 10:09 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 12:59 PM
Supposedly 'new' roof is leaking beejay Roofing/Siding 3 03-06-2007 11:55 AM
