Roof Leaking Behind Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-17-2011, 09:45 AM   #16
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
...sorry...
how do you attach the formed piece of flashing "gutter apron extension"..?
I'm not trying to be a d!ck here, but I really would like to see this flashing detail.
If it can be done in a professional manner, I'm all for it.
Does it match the color of the gutters?
...and again...how is it attached?
tcleve4911 is offline   Reply With Quote
Old 04-17-2011, 12:37 PM   #17
Residential Roofer
Slyfox's Avatar
Originally Posted by tcleve4911 View Post
...sorry...
You can attach it with finish nails (same used to fasten aluminum fascia covering) or zip screws.
The flashing itself and the fasteners both matching the color of the trim work (gutters/fascia coverings).
I didn't take your response as you being a d!ck, were both going to the same place, just using different paths to get there.
I don't have any pics of this detail, have only needed to use it a few times.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-17-2011, 12:45 PM   #18
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
We mostly do copper gutters, but frequently use the detail Sly is talking about. We usually pop rivet it to the back of the gutter. We sometimes rivet it to the drip edge if the drip edge is copper.
With aluminum, we match either the drip edge or the gutter. As far as looking nasty, it's usually not very visible unless you've got your head stuck in the gutter.
seeyou is offline   Reply With Quote
Old 04-17-2011, 07:08 PM   #19
Does anyone else do this I attach a 1x2 nailer at the edge of the decking then install the drip edge. It's always at least 3/4 of an inch into the gutter
Don Smith is offline   Reply With Quote
Old 04-20-2011, 06:06 PM   #20
Veteran Rehabber
Thumbs up
Ugly Fix
Originally Posted by Slyfox View Post
A flat stock flashing slid up under the face of the drip edge and over the top backside of the gutter will do the same job as the positive right flow.
I wish I had read your comment last fall. My tenant complained about lots of water dripping between gutter & fascia. Tried caulk but it only lasted until the first hard freeze. I put aluminum Z flashing under drip edge and over gutter lip to stop the drips, using metal screws to attach to to gutter lip. It worked but looked really nasty. Either gutters hung too low or drip edge was too short for the situation. Thanks for the tip.
CMHbob
Visit my blog for latest project and reno tips!
CMHbob is offline   Reply With Quote
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Leaking Roof Where House Meets Porch tazmajazz Roofing/Siding 7 08-25-2010 07:18 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 07:51 AM
Mysterious leaking roof... Suggestions? AlbrightPM General DIY Discussions 8 10-30-2006 11:47 PM
