Roof Leaking 5 Ft. Below Exhaust Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-27-2011, 09:29 PM   #61
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Also note that the improperly nailed shingle was sliding, hence the slot below the nail.
tinner666 is offline   Reply With Quote
Old 10-28-2011, 08:32 AM   #62
Pro Slate Roofer
tinner666's Avatar
You lucky dog, you! I was writing a proposal this morning and spotted a roof I did 12 years ago with the same vent in it. It was probably black when I installed it. Obviously, my plan 'B' was the correct one to follow as I stated earlier.
No storm shield, no caulk, no leak. I didn't even caulk the nails which won't rust because I only used roofing nails, not those EG you see in Lowes, or elsewhere.
roof leaking 5 ft. below exhaust vent-bathroom-vent.jpg   roof leaking 5 ft. below exhaust vent-bathroom-vent-2-.jpg
Old 10-28-2011, 09:43 AM   #63
AGWhitehouse's Avatar
Originally Posted by MJW View Post
I've installed hundreds of these and possibly thousands of roof vents with no tar or roofing cement. Never had one leak yet. Those instructions are for people who walk into Menards to buy one and have never even seen one before.
Spoken like a true contractor. "I don't follow those, they are for people who dont know what they're doing"...haha. Remember that abundant experience doing it the wrong way doesn't make it the right way. I've done lots of jobs where contractor's have to remove and replace things they've done because "I didn't read the plans, I just did it the way I always do it."
Tell me how that is any different than a flashing on the wall or a roof vent. No one seals roof vents or flashing. It just creates problems.
As I said, any flashing system should be installed to not need caulking. Caulk should and always be a secondary measure. If it leaks without caulk, it will leak with caulk. If it doesn't leak without caulk it shouldn't leak with caulk. I've never known caulk to create problems when it was installed as a secondary measure unless, of course, it was installed poorly as shown in tinner's pic....
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-28-2011, 12:19 PM   #64
Pro Slate Roofer
tinner666's Avatar
Originally Posted by Pirateghost View Post
My roofer installed mine. It leaked with no sealant. Can you explain that?
There could also be another explanation. Those vents are made of cheap metal with a single hem, and maybe tack-welds. When I looked at the one I installed, I realized there are two other things I do as normal as breathing and would never remember to comment on.
1st.- At the hemmed joints, I apply a gutter sealer on those joints inside AND outside hours before the install. 9Backup plan #1)
2nd. No matter what color it already is, I then paint it to match again because the coating they come with will allow them to rust through within a few years. Many never make it for the shingles' lifetime. My records show that I painted the one I installed silver.
These are things I do as second nature and never list them on my proposals. They are so necessary and so redundant that 'it goes without mention' so to speak that I will do them.
Old 10-28-2011, 03:32 PM   #65
MJW
Thank You.
If done correctly, you won't need a second measure.
Some people are just not cut out to do roofing, but they still do it anyways. Those types usually aren't in business for 30+ years either.
MJW is offline   Reply With Quote
Old 10-28-2011, 03:48 PM   #66
Well, lots and lots of rain, no leaks. I'll keep an eye on it. Not sure if I should rip it all up and re do it or not.
Pirateghost is offline   Reply With Quote
Tied in Porch Roof to Existing Roof - Leaking bharling Roofing/Siding 29 03-08-2011 05:06 AM
Is my roof going to start leaking soon? smithers76 Roofing/Siding 16 09-04-2010 06:10 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 03:50 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
Help- leaking flat roof, alum?metal? xoroniox Roofing/Siding 1 04-24-2006 11:03 AM
