roof leaking 5 ft. below exhaust vent
I had a sunroom addition put on about 6 yrs. ago. Maybe a yr. after the ceiling was leaking approx. 5 ft. below the exhaust fan that is there. So i decided to put a butt load of roof patch around it. It helped, we only got some water after ALOT of rain.
Now i am fed up with it and i want the builder to fix it. Well, he came over the other day, lifted all the shingles around it, supposedly repaired it. Well today we hardly had ANY rain and it is leaking at the same spot, i have pine bead board in the ceiling also. He stated it couldn't be leaking from the vent, he put some kind of adhesive or something around it, plus new shingles. I really don't think he knows what he is doing, this is the same guy that did it before. This time i want it fixed and not paying him a dime. I pd. him $130 cash to fix HIS OWN SCREWUP just a few days ago. He stated the aluminum wasn't right or something along that line. Any advice on this situation please! |
What you should have done is called him the first time it leaked 5 years ago.
Most of these kind of fixes are very simple and “never” require “a butt load of roof patch”. That said and not even getting into your contractor issues today, I’m sure all you want is to stop the leak and there are plenty of people here that can assist you with that. All you need to do is post a picture or two of the vent, standing far enough back so we can see the area around and above it.:thumbsup: |
5 Attachment(s)
Anyway, here are the pics., it is a real big roof. |
That’s definitely not installed correctly and having a valley pouring into it doesn’t help anything.
If you could move the vent over a bay or two I would. If the guy that installed it is who your beating with a stick to come back, forget it, just write him off. Get an experienced roofer in there to fix this simple issue. It may or may not be DIY, don’t know your skill level. Did I say move the vent? |
Also, this guy is going to have to make it right, he has done tons of work for us. I just pd. him $130 to fix this with my shingles. When he comes to fix this again he is not getting pd. anyway, though he does not know it yet. What do you recommend to fix this besides moving the vent, cause that is not gonna happen. |
I’m no roofer, I’m just the siding guy.
Although I do know about drainage planes, water management, and I can think like a raindrop. Obviously your guy can’t. I’m sure he built you a beautiful sunroom but if he can’t see the obvious than you should find someone that can. |
I'm no roofer, but I see several issues with this set up (nevermind it being located right where a valley dumps into it, as someone said).
* That vent needs to be replaced as it is rusting out. Water could be coming into the location on the side where the vent meets the flashing where there is rust. When it is replaced, have the roofer install ice and water shield over the flashing. * The bottom part of the flashing needs to be exposed OVER the shingles. That way, as water flows down the roof, it will direct on top of the flashing which is ABOVE the shingles. The set up that you have right now will direct water UNDER the shingles. * If you cannot move the vent, have a roofer install these angled flow diverters/channels to see if that helps. |
I think they're saying the vent lip should look this way:
http://www.single-family-home-remode...roof-vents.jpg The "downhill" lip should be on top of the shingle so water flows from upper shingle ~> vent lip ~> lower shingle. The way yours is funnels water under the edge of the lower shingles. Looks nice, doesn't work. |
In any regard, I think you should replace it as it is starting to rust. Is there any way you can access the attic area directly under the roof? |
Mayhem -
What's the slope of that roof? I've had some trouble with similar units leaking on 4/12 and lower slopes. But, it's not installed correctly as previously noted. The flange on the front of it needs to lap over the shingles, not under. I'm pretty sure that's a Broan/Nutone vent jack. It may have been re-branded as Panasonic. Here's the installation instructions: http://www.broan.com/ImageLibrary/br...s/99041929.pdf |
Don’t you install the vent to the felt in the same fashion with the lower part of the flange over the felt with the felt over the top of the flange?
I would think is papered properly and roofed as shown it still shouldn’t leak into the house. The water should run between the roofing and felt. |
| All times are GMT -4. The time now is 04:58 AM. |
