Roof Leak Only In Winter - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-21-2012, 10:14 AM   #1
Roof leak only in winter
I have a section about 10-15' where a new structure connects to an existing structure where I get ice build up which ends up with a leak. Can some type of ice sheild be installed over the existing asphalt shingles which are in good condition?
Mary.Ryder is offline   Reply With Quote
Old 04-21-2012, 10:17 AM   #2
Rewards Points: 14,294
Nope, going to have to post a picture if you want some better suggestions.
Most often ice damms area caused from poor insulation and poor venting.
So that will need to be addressed as well.
The valley flashing is done under the shingles not on top of it.
http://www.energystar.gov/index.cfm?...sulation_table
Old 04-21-2012, 11:32 AM   #3
Rewards Points: 790
The only good way would be to remove the current shingles in the area and inspect the wood decking below. If ice/snow builds up in this area, even a proper roof job might not correct incorrect pitch or construction of the new/old areas. Ice and water barrier should be used in ALL valleys as well as the bottom 3 feet of the roof.
Keep in mind ice/water barrier doesn't prevent ice dams, but helps them from causing damage to the roof and ceiling below.
cibula11 is offline   Reply With Quote
The Following User Says Thank You to cibula11 For This Useful Post:
Gymschu (05-08-2012)
Old 04-21-2012, 07:01 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Certainteed Winterguard is the only Ice and Water that is warranted from any ice dam leaks.
Roofmaster417 is offline   Reply With Quote
trying to patch flat roof - leak in seam Camera Roofing/Siding 2 11-02-2011 10:25 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Determining Roof Leak after Repairs wallace1 Roofing/Siding 4 11-01-2009 11:32 AM
Flat Roof Leak stubits Roofing/Siding 3 06-27-2009 03:30 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
