#16 |
old timer
Roof Leak Near Chimney
RichardZ,
Excellent advice from Frank (tinner). Here are some links to more pics and a video to help you visualize. Chimney flashing information Chimney flashing video Also, when re nailing with the fluted masonry nails, drill a pilot hole (slightly smaller in diameter) in the masonry to prevent blowing out the mortar.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 |
RichardZ,
I had a link to a flashing kit on here- but it was deleted. Not sure what i did wrong... I'll try again: http://www.lyonscontracting.com/blog/flashing-repair good luck with the job! Last edited by Lyonsco; 12-23-2011 at 04:38 PM. |
#18 |
Pro Slate Roofer
"Excellent advice from Frank (tinner)."
Not so excellent advice! I forgot to tll him those triangles need to overlap each other by 3-4".
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Tags |
flashing, leaking, roof ![]() |
| Display Modes | |
| Roof leak nightmare..... it won't stop | amandat37 | Roofing/Siding | 52 | 04-22-2011 01:47 PM |
| Leak around chimney - metal roof | nelsonC | Roofing/Siding | 1 | 09-30-2010 09:56 PM |
| Roof fans sucking air through chimney? | Badfish740 | HVAC | 8 | 10-08-2008 11:01 AM |
| leak in chimney water comes threw brick | Kdawg | Roofing/Siding | 51 | 02-08-2008 04:18 PM |
| flat roof leak | snikda9 | Roofing/Siding | 16 | 01-26-2006 05:25 PM |
