Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-05-2011, 02:21 PM   #1
roof leak caused by furnace pipe.
When i had to replace the furnace ever since I have had problems with a pipe coming from the furnace that is hot to the toucch when furnace on. This pip previously was just open at the base to the outside.
The heated pipe causes ice dams wound it and snow melts that leak right in ti the kitchen below. And then runs underneath and is causing staining and water damag.-that I hac never had in fifteen years. Have had ice cam leak at the wall but never all the way down.
suzyp is offline   Reply With Quote
Old 02-06-2011, 12:02 AM   #2
RFN-4A-LVN
Roofmaster417's Avatar
I am not for sure but it sounds like the flashing around the pipe that meets the roof deck was improperly installed.I would have a pro look at the installation of the flashing around the furnace pipe.Could you post a picture from the ground?
Roofmaster417 is offline   Reply With Quote
Need Help Chimney/stink pipe flashing leak pics bfan781 Roofing 11 04-01-2010 04:57 PM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 06:54 PM
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
Leak in Soil Pipe mark2741 Plumbing 6 08-30-2009 09:50 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
