Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-22-2009, 12:45 PM   #1
KennyS
Roof Leak - Asphalt Tiles Don't Overlap Correctly
Asphalt tiles don't overlap correctly. It's as if two roofers worked around opposite ends of the roof and met up here to finish the job. The gap runs vertically from gutter to rooftop flashing. After a few years the caulking they probably applied simply is starting to perish. What is the best way to correct this problem?
KennyS is offline   Reply With Quote
Old 09-22-2009, 03:49 PM   #2
Commercial Roofing
AaronB's Avatar
Hire someobody that kows what theyre doing instead of what most homeowners do with hiring the cheapest.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-22-2009, 03:54 PM   #3
KennyS
Thanks, AaronB. You are absolutely right about getting what you pay for. I inherited the problem when I bought my home and I am just trying to learn the best DIY solution.
Old 09-22-2009, 06:28 PM   #4
Xtreme DIY'r
Is the roof OK otherwise?
Any idea how old it is.....any signs of curling other problems?
Any plans to redo the roof?
Do you know if there is 1 layer or 2 layers of shingles on the roof?
I assume the leak is along this caulk/joint line?
Temp fix I'd go get some roof "caulk" & caulk it
Old 09-22-2009, 07:39 PM   #5
Remodeling Contractor
oldfrt's Avatar
You could also slip pieces of step flashing under the 'seam' from the bottom up,of course,and tack in place if shingles will lift up without tearing them.
Sometimes,if the roof isn't too old, a good roofer could cut in the proper stepping with matching shingles.
oldfrt is offline   Reply With Quote
Old 09-22-2009, 10:42 PM   #6
Commercial Roofing
AaronB's Avatar
There is no fixing this properly without redoing the entire side.
Old 09-23-2009, 09:30 AM   #7
General Contractor
I am going to agree with Aron B, you need to re roof the structure properly. Any other attempt to repair will be a short term temporary solution at best. The cost to re roof the structure with asphalt shingles is very nominal especially when compared with the costs to repair water damage within the structure and to eliminate any mold issues that may arise from it.
ARI001 is offline   Reply With Quote
Finding leak in flat roof Thurman Roofing 2 08-01-2009 09:47 AM
Advice on repairing roof leak... perpetualjon Building & Construction 10 06-10-2009 01:36 PM
garage roof leak Chicago Bill Roofing 8 05-05-2009 02:07 PM
New Roof Vs Insurance Miranda Roofing 3 10-19-2008 01:51 PM
